    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
List of Recalls (From Vehicles to Toys)
SkyJumper
DISABLED AIRBORNE VET
Moderator Emeritus
SW Florida
1999 Expedition XLT 4x4
My attorney sends me monthly recalls on items. This month I thought it to be useful to all here as Ford and Mercury are listed in these recalls.
National Highway Transportation Safety Administration’s (NHTSA) Office of Defect Investigation (ODI) and Consumer Product Safety Commission (CPSC) announces new Recalls & Alerts:
Kia Airbag Recall
Kia has issued a recall of approximately 145,000 vehicles due to a defect affecting the frontal airbags. The following vehicles are included in the recall class: 2006-2008 Kia Optima vehicles manufactured from September 29, 2005 through January 29, 2008 and 2007-2008 Kia Rondo vehicles manufactured from September 13, 2006 through March 21, 2008. Over time, the clock spring contact assembly for the driver's side airbag supplemental restraint system (SRS) may become damaged. If this occurs, the airbag electrical circuit may experience a high resistance condition that prevents the driver's airbag from deploying, significantly increasing the risk of enhanced injuries in the event of a crash.
The recall is expected to begin sometime in March 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Kia Customer Service directly at 1-800-333-4542 and reference safety recall no. SC094. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V014000.
Toyo Tire Recall
Toyo Tires has issued a recall of approximately 68,000 Extensa A/S tires (P225/60R16 97T) produced from September 20, 2009 through November 6, 2010. Some of these tires may have been produced with a kink in the bead area, which under certain circumstances can eventually crack. If left undetected, this can lead to tire failure, significantly increasing the risk of crash and catastrophic injuries.
The recall is expected to begin on February 2, 2012 and dealers will inspect the vehicle and provide replacement tires free of charge. Owners may contact Toyo directly at 1-800-442-8696. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T002000.
Britax Child Seat Recall
Britax has issued a recall of approximately 14,000 Chaperone Infant Child Restraint Systems produced from September 1, 2010 through April 30, 2011. The recall is due to a defect that can cause the harness adjuster to detach from the seat shell. If this occurs, a child may not remain properly restrained, significantly increasing the risk of enhanced injuries in the event of a crash.
Britax is expected to provide repair kits free of charge beginning on February 6, 2012. Owners may contact Britax directly at 1-888-427-4829. Proper safety restraints are critical to a protecting a child in a vehicle. Parents are encouraged to learn more about child passenger safety by visiting the safe kids section of our website. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12C001000.
Ford Recall: Freestar & Mercury Monterey Vehicles
Ford has issued a recall of approximately 200,000 Freestar and Mercury Monterey vehicles due to a defective torque converter. The malfunction, which affects certain 2004 and 2005 vehicles, can result in a sudden loss of motive power, significantly increasing the risk of crash.
The recall is expected to begin in the second calendar quarter of 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Ford directly at 1-866-436-7332 and reference safety recall no. 11S25. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V006000.
Ford Recall: Ford Escape
Ford has issued a recall of approximately 244,000 vehicles manufactured from October 22, 1999 through July 19, 2002. Certain 2001-2002 vehicles may be equipped with a defective brake master cylinder reservoir cap that can leak brake fluid. A brake fluid leak can cause corrosion to develop in the electrical connector leading to melting, smoke or a fire.
The recall is expected to begin on or around January 23, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Ford directly at 1-866-436-7332 and reference safety recall no. 11S24. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V005000.
Mazda Tribute Recall
Mazda has issued a recall of approximately 52,000 Tribute vehicles manufactured from April 20, 2000 through July 19, 2002 due to a defect impacting the brake system. A brake fluid leak in the master cylinder reservoir cap can reach the antilock brake system (ABS) module wiring harness connector. This contact can cause corrosion in the electrical connector, increasing the risk of melting, smoke or a fire.
The recall is expected to begin on January 30, 2012 and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Mazda directly at 1-248-393-5990 and reference safety recall no. 6712A. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V016000.
BMW Recalls Mini Coopers
BMW has issued a recall of approximately 88,000 vehicles due to a defect impacting the engine and engine cooling system. The following automobiles are included in the recall class: 2007-2011 Mini Cooper S, 2008-2011 Mini Cooper S Clubman, 2009-2011 Mini Cooper S convertible, 2009-2011 Mini Cooper JCW, 2009-2011 Mini Cooper JCW Clubman, 2009-2011 Cooper JCW convertible, and 2011 Cooper S Countryman passenger cars manufactured from November 14, 2006 through January 18, 2011. An electronic circuit board connected to the electric auxiliary water pump can malfunction and overheat. If this occurs, the circuit board may smolder increasing the risk of a vehicle fire.
The recall is expected to begin sometime in February 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact BMW directly at 1-866-275-6464. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V008000.
Owners are encouraged to contact the National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153) or go to www.safercar.gov with any questions or concerns surrounding these or any other recalls or safety campaigns.
SkyJumper
Moderator Emeritus
SW Florida
Volkswagen Recalls New Beetles for Non-compliance in Crash Protection Requirements
Volkswagen is recalling approximately 27 New Beetle and New Beetle convertibles manufactured between September 1, 2010 and September 22, 2010. Certain vehicles produced in that time frame do not comply with Federal requirement safety standard NO. 208 (frontal impact crash test) for Occupant Crash Protection that went into effect on September 1, 2010.
The recall is expected to begin on February 1, 2011 and dealers will offer to replace the vehicle with a comparable vehicle that is in compliance. Owners may contact Volkswagen directly 1-800-822-8987. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 11V031000.
425,000 Ford Windstar Minivans Recalled
Ford is recalling approximately 425,000 Windstar vehicles due to a defect that can cause the separation of a front lower control arm rear attaching bracket, which can lead to the separation of the steering intermediate shaft. This defect affecting certain 1999-2003 Windstar vehicles can result in reduced steering control and increase the risk of a crash.
The recall is expected to begin on or before February 14, 2011, and dealers will inspect the vehicle and perform any necessary service free of charge. Owners may contact Ford directly 1-866-436-7332 and reference Ford's safety recall No. 11S16. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 11V030000.
Toyota Issues Lexus Recall for Fuel Leak Defect
Toyota is recalling approximately 244,000 vehicles due to a defect affecting the fuel pressure sensor which connects to the engine fuel delivery pipe. This defect in certain 2009 LEXUS IS and 2006-2007 LEXUS GS vehicles can cause a fuel leak, which can increase the risk of a fire.
The manufacturer has not yet provided an owner notification schedule, but once determined, dealers will inspect the vehicle and perform any necessary service free of charge. Owners may contact Toyota directly 1-800-331-4331. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 11V029000.
Ducati Recalls 3,900 Motorcycles
Ducati is recalling approximately 3,900 motorcycles for a defect affecting the fuel tank pump flange seal. The recall of certain 2006 Multistrada 620, 2003-2006 Multistrada 1000 and 2007-2009 Multistrada 1100 Motorcycles, is due to the increased risk of a fuel leak, which can lead to a fire.
The manufacturer has not yet provided an owner notification schedule, but once determined, dealers will inspect the vehicle and perform any necessary service free of charge. Owners may contact Ducati directly 1-800-231-6696. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 11V020000.
Owners are encouraged to contact the National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153) or go to www.safercar.gov, with any questions or concerns surrounding these or any other recalls or safety campaigns.
Rosebud Crib Recalls for Entrapment, Suffocation and Fall Hazards
A recall has been issued for approximately 300 Rosebud drop-side cribs due to entrapment, suffocation and fall hazards. The drop side rail hardware on the cribs can fail or break creating a gap where babies can get wedged, increasing the risk of suffocation and strangulation. Further, the rail failure increases the risk that a child can fall out of the crib. There have been 13 reported incidents of the crib malfunction, though no injuries to date.
The Rosebud cribs are white or antique white and have plastic drop-side hardware. "Status Furniture" appears on the crib labeling located on the lower portion of the headboard, and model number "910" appears on the assembly instructions.
Consumers should stop using these cribs immediately and contact the distributor (The Land of Nod) to receive instructions on how to receive a merchandise credit for the full purchase price of the crib ($599). For additional information, contact The Land of Nod (800) 933-9904 or visit the firm's website www.landofnod.com.
Butterfly Pushtoy Recall
A recall has been issued for approximately 1,400 Butterfly Push toys due to a possible choking hazard caused by small metal balls inside the butterfly's wings. The plastic butterflies have movable wings, each containing 1 ½ inch balls. If the wings are accidently broken, the metals balls within can be hazardous to the child. The item number of the toy is L185819 (listed on a sticker on the package) and was sold at flea markets in North Carolina and South Carolina from May 2010 through October 2010 for about $2.
Consumers should immediately take the recalled toys away from young children and return them to the place of purchase or contact Kang Sheng Group to receive a full refund or replacement. For additional information, contact Kang Sheng Group (877) 485-7285.
To report a dangerous product or a product-related injury, call CPSC's Hotline at (800) 638-2772 or CPSC's teletypewriter at (800) 638-8270. Consumers are encouraged to obtain more details on recalls and general safety information by logging on to CPSC's Web site at www.cpsc.gov.
SkyJumper
Moderator Emeritus
SW Florida
National Highway Transportation Safety Administration's (NHTSA) Office of Defect Investigation (ODI) and Consumer Product Safety Commission (CPSC) announce new Recalls & Alerts:
General Motors Recalls 2011 SUVs
General Motors is recalling approximately 26,000 Model Year 2011 Cadillac Escalade, Escalade ESV, Escalade EXT; Chevrolet Avalanche, Colorado, Silverado, Suburban, Tahoe; And GMC Canyon, Sierra, Yukon And Yukon Xl Vehicles. The recall is due to a defect affecting the rear axle cross pins that could create an interference and cause the driver to lose directional control of the vehicle, increasing the risk of crash.
The safety recall is expected to begin on January 25, 2011 and dealers will perform the necessary service free of charge. Owners may contact the owner center directly http://www.gmownercenter.com. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 11V007000.
SAAB issues recalls for Fuel Pump Defect
SAAB is recalling approximately 4,400 vehicles manufactured from June 2010-December 2010 for a defect affecting fuel pumps. Internal components were installed with incorrect specifications in certain 2010 and 2011 passenger vehicles which can cause the engine to stall and increase the risk of crash.
The safety recall is expected to begin on February 18, 2011. Saab will notify owners and replace the defective fuel pumps free of charge. Owners may contact Saab directly 1-800-955-9007 and reference Saab campaign ID number 15029. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 11V015000.
Owners are encouraged to contact the National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153) or go to: www.safercar.gov, with any questions or concerns surrounding these or any other recalls or safety campaigns.
Jogging Strollers recalled for Amputation/Laceration Hazards
A recall has been issued for approximately 30,000 jogging strollers manufactured by Phil&Teds USA, Inc., due to the threat of finger tip amputation or laceration caused by a hinge mechanism used to fold and unfold the stroller. The recalls encompass the following stroller models: sport v2 (serial number 0308/0001 to 0510/0840) and classic v1 model (0308/0001 to 0510/0906) single-seat jogging strollers. The three-wheel strollers have a metal frame, cloth seat and a canopy, and the serial numbers are printed on the inside of the folding hinge.
Consumers should stop using the recalled strollers immediately and contact Phil&Teds USA to arrange for a free hinge-cover kit and repair instructions. For additional information, contact Phil&Teds USA at (877) 432-1642 visit: www.philandteds.com/support.
To report a dangerous product or a product-related injury, call CPSC's Hotline at (800) 638-2772 or CPSC's teletypewriter at (800) 638-8270. Consumers are encouraged to obtain more details on recalls and general safety information by logging on to CPSC's Web site at: www.cpsc.gov.
SkyJumper
Moderator Emeritus
SW Florida
National Highway Transportation Safety Administration’s (NHTSA) Office of Defect Investigation (ODI) announces new Recalls & Alerts:
Chrysler Recalls Dodge Charger Police Vehicles
Chrysler has issued a recall of approximately 9,688 Dodge Charger police vehicles due to a defect affecting the low beam headlamps. The headlamps in certain 2011 and 2012 vehicles may fail due to an overheated bulb harness connector. Other vehicles may lose abs/esc system function due to an overheated power distribution center. This could lead to loss of visibility and/or braking ability, increasing the risk of a crash.
The recall is expected to begin sometime in March 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Chrysler directly at 1-800-853-1403 and reference safety recall no. M01. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V042000.
Nissan Versa Recall
Nissan has issued a recall of approximately 36,000 Versa vehicles equipped with an automatic transmission and manufactured from June 9, 2011 through January 13, 2012. Certain 2012 vehicles fail to comply with Federal Motor Vehicle Safety Standard No. 114 regarding “Theft Protection and Rollaway Prevention.” Due to interference between the shifter rod and the shift knob, the vehicles may be shifted out of the park position without depressing the brake pedal. The operator can inadvertently shift the vehicle into gear without the brake pedal being depressed, increasing the risk of a crash or injury to a nearby pedestrian.
The recall is expected to begin on February 20, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Nissan directly at 1-800-647-7261. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V032000.
Honda Airbag Defect Recall
Honda has issued a recall of approximately 347 Accord and Crosstour vehicles due to a defect affecting the driver or passenger-side curtain airbags. The airbag inflator in certain 2012 vehicles may not have been manufactured according to the correct specifications. The defective airbag may fail to deploy in a crash, significantly increasing the risk of enhanced injuries.
The recall is expected to begin on or about February 10, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Honda Customer Service directly at 1-800-999-1009. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V030000.
Toyota Airbag Defect Recall
Toyota has issued a recall of approximately 427 RAV4 vehicles manufactured from November 24, 2011 through December 19, 2011. The propellant used for the initiator assembled in the curtain shield airbag inflator may not be the proper specification. In this condition, the inflator may not perform properly, preventing one or both curtain shield airbags from deploying in a crash and significantly increasing the risk of enhanced injuries.
The recall is expected to begin sometime in March 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Toyota directly at 1-800-331-4331. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V029000.
SkyJumper
Moderator Emeritus
SW Florida
Goodyear Tire Recall
40,000 defective Goodyear tires have been recalled for their propensity to experience a tread separation while the vehicle is in operation. A tread separation significantly increases the risk that an operator will lose control of their vehicle and experience catastrophic or fatal injuries.
Goodyear has issued a recall of Wrangler Silent Armor Tires in the following sizes: LT235/80R17 LRE, LT325/60R18 LRE, LT275/70R18 LRE, LT265/70R17 LRE, LT245/75R17 LRE and LT285/70R17 LRD, produced from March 31st through May 31st, 2009.
The recall is expected to begin sometime on or before March 22, 2012, and dealers will inspect the vehicle and replace the tires free of charge. Owners may contact Goodyear directly at 1-800-592-3267. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T003000.
Nissan Recall: Fuel System Defect
Nissan has issued a recall of approximately 79,000 Juke, Infiniti QX and Infiniti M vehicles due to a fuel pressure sensor defect. The sensors in certain 2011-2012 vehicles may not have been tightened to the proper specifications which can lead to a fuel leak. A fuel leak can compromise the integrity of the fuel system significantly increasing the risk of a fire.
The recall is expected to begin on March 19, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Nissan directly at 615-725-1000. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V069000.
Honda Recall: Fuel System Defect
Honda has issued a recall of approximately 8,709 Pilot and Acura MDX vehicles due to a fuel system defect. The vent shut float (VSF) valve case in certain 2012 vehicles does not meet design specifications, resulting in a possible fuel leak. A fuel leak significantly increases the risk of a fuel fed fire and enhanced injuries to motorists.
The recall is expected to begin on or about March 13, 2012, and dealers will inspect the vehicles and perform the necessary service free of charge. Owners may contact Honda customer service directly at 1-800-999-1009 and reference safety recall No. S25 and S26. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V063000.
Nissan Murano & Rogue Recall
Nissan has issued a recall of almost 3,000 Murano and Rogue vehicles manufactured from November 23, 2011 through January 11, 2012. The tire pressure monitoring system (TPMS) in certain 2012 vehicles may not have been activated during assembly, failing to comply with Federal Motor Vehicle Safety Standard No. 138 regarding “Tire Pressure Monitoring Systems.” Maintaining appropriate tire pressure is critical to vehicle safety, as underinflated tires can lead to tire failure while the vehicle is in operation. Tire failure can significantly increase the risk of an accident and catastrophic injury.
All of the affected vehicles are currently in dealer inventory and dealers will inspect the vehicle and activate the system. Owners purchasing one of these vehicles should make inquiries with the dealer to ensure the defect has been addressed before completing the sale. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V068000.
Volvo Recall
Volvo has issued a recall of approximately 17,000 S60, XC60, S80 and XC70 vehicles manufactured from May 16, 2011 through October 6, 2011. In certain 2012 vehicles, the wire harness under the front seats may not be properly attached to the seat frame. As a result, when the seats are moved to adjust the seating position, the wire harness may get pulled, causing it to disconnect. In the event of crash, the front and/or side impact airbags may deploy improperly or not at all, increasing the risk of enhanced injury. Further injury can also occur as the lap belt pretensioner may not deploy.
The recall is expected to begin on March 30, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Volvo directly at 1-800-458-1552. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V075000.
Honda Odyssey Recall
Honda has issued a recall of approximately 45,000 Odyssey vehicles due to a manufacturing flaw affecting the gas-filled struts that help to raise and support the liftgate of vehicles equipped with a power liftgate system. The defect can result in a leak of pressurized gas leading to reduced strut performance, unexpected closure and increased risk of personal injury.
The recall is expected to begin on or about March 13, 2012, and dealers will inspect the vehicles and perform the necessary service free of charge. Owners may contact Honda customer service directly at 1-800-999-1009 and reference safety recall No. S22. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V062000.
Nissan Quest Recall
Nissan has issued a recall of approximately 23,531 Quest vehicles manufactured from July 29, 2010 through February 21, 2012. Due to a software programming defect, the engine may stall on certain 2011-2012 vehicles traveling at slow speeds or idling on a decline with ¼ tank fuel or less. This is a result of insufficient fuel reaching the engine.
The recall is expected to begin sometime in March 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Nissan directly at 1-800-647-7261. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V076000.
Kawasaki Recall
Kawasaki has issued a recall of certain 2008-2011 NINJA ZX-10R and 2009-2012 NINJA ZX-6R motorcycles manufactured from December 14, 2007 through July 26, 2011. Approximately 20,512 motorcycles may contain a manufacturing error that prevents the regulator/rectifier from sufficiently charging the battery. If the battery discharges, the motorcycle may stall without warning, increasing the risk of a crash.
The recall was expected to begin sometime on or about February 27, 2012, and dealers will inspect the bikes and perform the necessary service free of charge. Owners may contact Kawasaki directly at 949-770-0400. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V064000.
SkyJumper
Moderator Emeritus
SW Florida
Consumer News: Sticky Accelerators Lead to Massive Ford Recall
submitted by Adam J. Langino
The Associated Press recently reported that Federal safety regulators are investigating sticky accelerators in as many as 1.9 million Ford Taurus and Mercury Sable sedans. The National Highway Traffic Safety Administration has received 14 complaints of Taurus sedans self-accelerating. The agency is investigating whether a faulty cruise control cable is to blame as it has the potential to detach and hold open a vehicle’s throttle. NHTSA’s investigation started in March and originally included 360,000 model year 2005 and 2006 Ford Taurus’s. It has since expanded its investigation to include the 2001 through 2004 model year Ford Sable.
As an important safety reminder, per NHTSA, if a car suddenly accelerates, drivers should brake firmly without pumping the brakes, shift the car into neutral, steer to a safe location and shut off the engine. If a car has a keyless ignition, drivers should know how to turn off the engine while the car is in motion, which may involve holding the button until the engine turns off. Finally, drivers should familiarize themselves with their vehicle’s controls so they know in advance how to put their car into neutral.
Consumer News: Foreclosure Abuse Settlement
Submitted by Gregory S. Weiss
Florida’s Attorney General formally entered a landmark $25 billion joint federal-state agreement with the nation's five largest mortgage servicers over foreclosure abuses and unacceptable nationwide mortgage servicing practices. The proposed agreement provides an estimated $8.4 billion in relief to Florida homeowners and addresses future mortgage loan servicing practices. The settlement generally releases civil claims related to robo-signing, other foreclosure-related abuses, and loan origination misconduct, but it provides no release of criminal claims or of claims related to mortgage securitization. Florida’s share of the total monetary benefits under the settlement is approximately $8.4 billion.
Leopold Law has been engaged in class action litigation over wrongful foreclosure practices in federal court simultaneously with the state attorneys general settlement. If you experience issues involving the wrongful practices of financial institutions, contact our class action litigators www.leopold-law.com.
Legislative News: Changes to Personal Injury Protection (PIP) Insurance Coverage
Since 1972, Florida law required that all drivers carry basic personal injury protection (PIP) insurance. PIP provides $10,000 to cover medical bills and lost wages after an accident regardless of who was at fault. The following new conditions now apply to PIP policies and will become effective on July 1, 2012 (medical changes effective January 1, 2013).
The legislation requires an accident victim to obtain treatment within 14 days in an ambulance or hospital, or from a physician, osteopathic physician, chiropractic physician, or dentist.
The full $10,000 PIP medical benefit is available only if a physician, osteopathic physician, dentist, or a supervised physician's assistant or advanced registered nurse practitioner determines that the insured has an "emergency medical condition." If this condition is not met, the PIP medical benefit is limited to $2,500.
An "emergency medical condition" is defined as a medical condition manifesting itself by acute symptoms of sufficient severity, which may include severe pain, such that the absence of immediate medical attention could reasonably be expected to result in any of the following: (a) Serious jeopardy to patient health (b) Serious impairment to bodily functions (c) Serious dysfunction of any bodily organ or part.
Follow-up services and care requires a referral from a physician, osteopath, chiropractor or dentist. Massage therapy and acupuncture are not eligible PIP benefits.
Examination under oath. If the patient does not show-up, their PIP benefits are eliminated.
Please take note of these changes in the law so that you are educated and aware of the how your mandatory insurance is structured and the benefits that are available to you. Click here for complete bill language and legislative update.
SkyJumper
Moderator Emeritus
SW Florida
National Highway Transportation Safety Administration’s (NHTSA) Office of Defect Investigation (ODI) and U.S. Consumer Product Safety Commission announces new Recalls & Alerts:
BMW Recalls 1.3 Million Luxury Cars
BMW has issued a recall of approximately 1.3 million vehicles due to an insulated bulkhead connector defect. The positive battery cable in certain 2004-2010 5-Series, 2004-2010 6-Series, 2006-2010 M5, and 2007-2010 M6 vehicles may have been incorrectly attached to the trunk floor panel, which can lead to a loosening of the bolt connection. As it loosens, an increase in electrical resistance at this cable connection is possible and could cause the cable connection to overheat. Overheating could lead to a fire, even while the vehicle is not in use. As a precaution, owners are advised to park outside until the remedy has been made.
The recall is expected to begin sometime in April 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact BMW directly at 1-800-525-7417. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V126000.
Yokohama Tire Recall
Yokohama has issued recalls for the following tires: Yokohama replacement tires, size 205/50R16 A680 87V, manufactured between September 1, 2007 and November 28, 2009 and Yokohama tires, size P215/60R15 AVID H4S 93H, manufactured between December 2, 2007, and September 19, 2009. The tires fail to conform to the requirements of Federal Motor Vehicle Safety Standard No. 139, regarding "New Pneumatic Radial Tires for Light Vehicles." Certain tires do not contain the complete Tire Identification Number (TIN) or partial TIN as required. The TIN is important so consumers can properly identify their tires in the event a safety-related performance notice is issued. Diligent attention to tire safety can have life saving value for motorists, and significantly decreases the risk of a crash.
The recall is expected to begin on April 6, 2012, and Yokohama will notify registered owners and provide free replacement tires free of charge. Owners may contact Yokohama directly at 1-888-801-4162. Additional details can also be found by referencing NHTSA CAMPAIGN ID Numbers: 09T014000 or 10T001000.
GTC Tire Recall
12,000 defective GTC tires have been recalled due to blistering on the sidewall, that over time, can cause tread separation while the vehicle is in operation. Tread separation significantly increases the risk that an operator will lose control of their vehicle and experience catastrophic or fatal injuries. The recall class consists of Advance Extra Grip AR215 light truck radial tires, size P235/75R15, produced from September 2008 through December 2009. These defective tires fail to conform to the requirements of Federal Motor Vehicle Safety Standard No. 139, regarding "New Pneumatic Radial Tires for Light Vehicles.”
The recall is expected to begin sometime in March 2012, and dealers will inspect the vehicle and replace the tires free of charge. Owners may contact GTC directly at 1-330-498-5000. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T004000.
Toyota Air Bag Defect
Toyota has issued a recall of approximately 495,000 Tacoma vehicles due to defect that can prevent the driver’s side airbag from deploying in the event of a crash. Certain 2005-2009 vehicles manufactured from September 14, 2004 through August 29, 2008 are subject to the recall. Over time, steering wheel vibration may damage the spiral cable assembly that powers the driver’s airbag module. If damage occurs, the airbag may become deactivated significantly increasing the enhanced injuries if an accident occurs.
The recall is expected to begin sometime in April 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Toyota directly at 1-800-331-4331. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V092000.
Subaru Forester Recall
Subaru has issued a recall of 275,000 Forester vehicles manufactured from November 26, 2007 through March 13 2012. Certain 2009-2012 vehicles may fail to comply with Federal Motor Vehicle Safety Standard No. 208 regarding “Occupant Crash Protection.” Specifically, the assemblies may not permit proper installation and secure attachment of a child restraint in that seating position. An insecure installation of a child restraint can significantly increase the risk of enhanced injuries to a child during a crash.
The recall is expected to begin on or before April 13, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Subaru directly at 1-800-782-2783 and reference safety recall No. WQA-37. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V099000.
Hyundai Sonata Recall
Hyundai has issued a recall of approximately 14,728 Sonata Hybrid vehicles produced beginning on December 2, 2010, and shipped to dealers through March 7, 2012. Certain vehicles equipped with a center rear seat belt incorporating a release mechanism that detaches both the lap and shoulder portion at the lower anchorage point, fail to conform to Federal Motor Vehicle Safety Standard No. 208 regarding “Occupant Crash Protection.”
Hyundai dealers are replacing the center rear seat belts in approximately 1,633 Sonata Hybrid vehicles currently in dealer inventory with center rear seat belts that are not detachable from the lower anchorage point prior to delivery to customers. For the approximately 13,095 vehicles that have been delivered to customers, Hyundai intends to file a petition for an exemption from the recall requirements of the National Traffic and Motor Vehicle Safety Act. Therefore, the manufacturer is not obligated to conduct an owner notification and remedy campaign until NHTSA has resolved this petition. If the petition is denied, the manufacturer will be notified and must then undertake its notification and remedy campaign obligations. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V098000.
Toyota Brake Light Defect
Toyota has issued a recall of approximately 186,000 Camry and Venza vehicles due to a defect that affects the exterior brake lights. The manufacturing defect can lead to any of the following malfunctions: warning lamps illuminate, a no start condition, the shift lever may not shift from the “park” position, or the vehicle’s brake lights could become inoperative. Inoperative brake lights will not warn other drivers that the vehicle is slowing or stopping, significantly increasing the risk of a crash.
The recall is expected to begin sometime in April 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Toyota directly at 1-800-331-4331. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V091000.
Chrysler Jeep Recall
Chrysler has issued a recall of approximately 209,724 Jeep Liberty vehicles manufactured from July 3, 2003 through July 14, 2005. Certain 2004 & 2005 vehicles may be equipped with rear lower control arms that can experience a rear suspension lower control arm fracture due to excessive corrosion. A fracture of the rear lower control arm may result in a loss of vehicle control and may lead to a vehicle crash.
The recall is expected to begin sometime in April 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Chrysler directly at 1-800-853-1403 and reference safety recall No. L27. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V085000.
Chevrolet Express, Suburban, GMC Savana and Yukon Recall
General Motors has issued a recall of approximately 6,159 Chevrolet Express, Suburban, GMC Savana and Yukon XL Heavy duty vehicles due to a steering defect. The steering gear pitman shaft in certain 2012 vehicles may not have been adequately hardened and could fracture. In the event this occurs, a loss of steering could result, increasing the risk of a crash.
The recall is expected to begin on April 4, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact NHTSA directly at 1-888-327-4236 and reference safety recall No. 12055. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V112000.
Child Safety Failure Leads to Recall of Safety 1st Cabinet Locks
The U.S. Consumer Product Safety Commission has issued a recall of approximately 900,000 Push 'N Snap Cabinet Locks. The locks are used for child proofing a home to prevent young children from accessing cabinet contents. Certain Safety 1st Push 'N Snap cabinet locks with model numbers 48391 and 48442 may not adequately secure the cabinet, posing a risk to children who can gain access to dangerous cleaning agents or other hazards within the home.
Push 'N Snap Cabinet Locks are sold at Bed Bath & Beyond and other retail stores nationwide for between $2 and $4. Click here for product detail.
Consumers should immediately remove the recalled locks from cabinets and contact DJG for a free replacement Push 'N Snap lock with model numbers HS158 or HS159. When removing the recalled locks, consumers are urged to immediately store dangerous items out of reach of children. For additional information, contact DJG toll-free at (866) 762-3212 or visit the firm's website at www.djgusa.com
SkyJumper
Moderator Emeritus
SW Florida
Chrysler Recall
Chrysler has issued a recall of approximately 119,072 Dodge 300 and Charger vehicles due to a malfunction in the power distribution center. Certain 2011 and 2012 vehicles may lose ABS/ESC system function if the power center overheats, which can lead to loss of vehicle control. Click here to see the MSNBC article regarding this recall.
The recall is expected to begin sometime in May 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Chrysler directly at 1-800-853-1403 and reference safety recall no. M10. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V197000.
Ford Windstar – Multiple Recalls
Ford has issued a recall of approximately 50,000 Windstar vehicles sold or registered in the state of Virginia.
Recall 1: Approximately 23,000 vehicles (model year 1999-2003), have been recalled due to a corrosion related fractures affecting the front lower control arm rear attaching brackets and body mount attachments. Separation caused by this defect can lead to significant loss of steering control, significantly increasing the risk of a crash.
The recall is expected to begin on June 18, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Ford directly at 1-866-436-7332 and reference safety recall no. 11S16. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V194000.
Recall 2: Approximately 27,000 vehicles (model year 1998-2003), have been recalled due to corrosion issues that can weaken the rear axle making it susceptible to torsional stress. Corrosion and stress can lead to cracks which can affect vehicle handling and increase the risk of a crash.
The recall is expected to begin on June 18, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Ford directly at 1-866-436-7332 and reference safety recall no. 10S13. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V193000.
Ford Recalls New F-150, Expedition, Lincoln Navigator & Mustang Vehicles
Ford has issued a recall of approximately 10,500 vehicles for failure to conform to the requirements of Federal Motor Vehicle Safety Standard No. 102 regarding “Transmission Shift Lever Sequence, Starter Interlock, And Transmission Braking Effect” and No. 108 regarding ““Lamps, Reflective Devices and Associated Equipment.” Certain 2011-2012 Ford F-150, 2012 Expedition and Lincoln Navigator, and 2012-2013 Mustang vehicles may have a transmission range sensor (TRS) that was calibrated out of specification for the reverse gear.
The recall is expected to begin on or around June 25, 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Ford directly 1-866-436-7332 and reference safety recall no. 12C23. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V190000.
BMW Recall – 3 Series
BMW has issued a recall of approximately 7600 3-series vehicles manufactured from October 19, 2011 through March 18, 2012. Certain vehicles fail to conform to the requirements of Federal Motor Vehicle Safety Standard No. 202A regarding “Head Restraints.” In the event of a vehicle crash, the head restraint may unexpectedly move down slightly if it was adjusted to the fully extended position, increasing the risk of enhanced injuries or death.
The recall is expected to begin sometime in May 2012, and dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact BMW directly 1-800-525-7417. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V176000.
Nissan Recall
Nissan has issued a recall of approximately 26,626 Titan and Armada vehicles for failure to conform to the requirements of Federal Motor Vehicle Safety Standard No. 110 regarding “Tire Selection and Rims.” The part 567 certification labels on certain 2012 vehicles do not contain rim size information, which is necessary to ensure correct tire/wheel combinations.
The recall is expected to begin on May 14, 2012, and dealers will supply owners with a new label. Owners may contact Nissan directly at 1-615-725-1000. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V143000.
Child Seat Recall – Dorel Juvenile
Dorel Juvenile has issued a recall of approximately 1,737 infant child restraints that were sold without the separate seat base that contains the required latch attachment assembly. The latch assembly is required for these units to conform to the requirements of Federal Motor Vehicle Safety Standard No. 213 regarding "Child Restraint Systems." Without the latch system, the seat may be more difficult to properly secure and in the event of a vehicle crash, the child may not be adequately protected and is at an increased risk for catastrophic and enhanced injuries.
The following models are included in the recall class: IC124FSM (ONBOARD 35) and IC123FSM (COMFY CARRY). The manufacturer will notify registered owners and distributors and provide replacement bases which include latch systems to all those who verify they have the affected units. Non-registered owners should call 1-877-416-8111 or email infantlatchrecall@djgusa.com. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12C002000.
SkyJumper
Moderator Emeritus
SW Florida
Kia Recall – Airbag Defect
Kia has issued a recall of approximately 72,568 RIO vehicles manufactured from February 20, 2005 – December 9, 2007. The front passenger seat occupant sensor mat in certain 2006-2008 vehicles may crack. In the event of sufficient cracking, the occupant classification system (OCS) will cease to function such that the system will not be able to detect whether a child passenger is in the seat. Air bag deployment with a child in the front passenger side seat significantly increases the risk of catastrophic injury to that child.
The recall is expected to begin sometime in July 2012. Dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Kia directly at 1-800-333-4542 and reference safety recall no. SC097. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V244000.
Kia Recall – Brake Pedals
Kia has issued a recall of approximately 21,912 Borrego vehicles manufactured from May 2, 2008 – January 20, 2009. Certain 2009 vehicles equipped with non-adjustable brake pedals, may have a fiberglass composition that allows them to break off in a collision, causing the vehicle to roll. If this occurs, the driver would need to stop the vehicle with the parking brake or experience a possible second impact, significantly increasing the risk of catastrophic injury.
The recall is expected to begin sometime during June 2012. Dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Kia directly at 1-800-333-4542 and reference safety recall no. SC096. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V245000.
Chrysler Recall – Transmission Skid Plate
Chrysler has issued a recall of approximately 67,872 Jeep Wrangler vehicles due to a malfunction affecting the transmission skid plate. The skid plate can collect debris which under certain conditions, can ignite without warning, resulting in a vehicle fire.
The recall was expected to begin during May 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Chrysler directly at 1-800-853-1403 and reference safety recall no. M22. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V216000.
General Motors Recall - Airbag Defect
General Motors has issued a recall of approximately 4,300 Chevrolet Malibu vehicles due to a defect that can cause the roof rail airbag to unintentionally deploy. Certain 2013 vehicles manufactured from October 24, 2011 through March 31, 2012 may be susceptible to this malfunction as a result of the Sensing and Diagnostic Module (SDM) resetting after a hard brake. Additionally, the air bags and/or seatbelt pretensioners may not deploy during a severe crash, increasing the risk of a catastrophic injury.
The recall is expected to begin on June 13, 2012. Dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact GM and reference safety recall no. 12102. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V224000.
Honda Recall – Power Steering
Honda has issued a recall of approximately 52,000 Acura TL vehicles (2007-2008), due to a defect that can cause the power steering hose to deteriorate prematurely, resulting in cracks and power steering fluid leakage. If this occurs, power steering fluid can leak onto a hot catalytic converter, leading to smoke and possibly an under-hood fire. Click here to read MSNBC article on this issue.
The recall is expected to begin on June 15, 2012. Dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Honda directly 1-800-999-1009 and reference safety recall no. S39. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V222000.
Suzuki Recall – Motorcycle
Suzuki has issued a recall of approximately 4,969 GSX-R1000 motorcycles due to a side stand interlock switch failure caused by loose bolts. On the GSX-R1000 models, failure of the switch will terminate the ignition circuit causing the engine to stop running and increasing the risk of a crash.
The recall is expected to begin sometime in June 2012. Dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Suzuki directly 1-714-996-7040 and reference safety recall no. 2A29. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V231000.
SkyJumper
Moderator Emeritus
SW Florida
Chevrolet Cruze Recalls – Multiple Fuel Fed Fire Hazards
General Motors has issued a recall of approximately 53,239 Chevrolet Cruze vehicles manufactured from October 2, 2009 through May 14, 2012. Certain 2011 and 2012 vehicles may lack attachment welds necessary to secure the fuel tank, increasing the risk of a fuel leak in the event of a crash. A fuel leak in the presence of an ignition source could result in a fuel fed fire.
The recall is expected to begin on July 11, 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Chevrolet directly at 1-866-694-6546 and reference safety recall no. 12133. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V289000.
General Motors has also issued a recall of approximately 413,148 Chevrolet Cruze vehicles manufactured from October 2, 2009 through May 31, 2012. Certain 2011 and 2012 vehicles may contain a defect that allows oil to collect in the engine shield near hot engine or exhaust system surfaces. The proximity of the oil to a heat source can cause the shield to ignite, resulting in an engine compartment fire and significantly increasing the risk of enhanced injuries or death.
The recall is expected to begin on July 11, 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Chevrolet directly at 1-866-694-6546 and reference safety recall no. 12081. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V288000.
Honda Recall – Civic Driveshaft Defect
Honda has issued a recall of approximately 50,190 Civic vehicles due to a manufacturing defect that can cause the car to roll away despite being placed in park, if the parking break has not been set. The process required to seat the driver’s side driveshaft and set the retaining clip was not completed during assembly. As a result, the driveshaft may separate, causing the vehicle to roll away and posing a significant danger to motorists and pedestrians.
The recall was expected to begin on June 21, 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Honda directly at 1-800-999-1009 and reference safety recall no. S40. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V256000.
SkyJumper
Moderator Emeritus
SW Florida
Massive Tire Recall
Thousands of tires have been recalled as a result of a manufacturing defect where contaminated rubber may have been used in the tread compound which could lead to tread separation. Tread separation can result in loss of vehicle control, increasing the risk of a vehicle crash and catastrophic injury.
The following tires have been identified in the recall class:
Cooper Tires: 10,236 Tires Recalled
Cooper Brand Discoverer H/T TIRES, sizes LT235/85R16 and P265/70R17; Discoverer LSX, size 265/70R17; and MasterCraft Courser HTR, size LT235/85R16. The recall was expected to begin on June 15, 2012. Dealers have agreed to inspect the tires and replace defective tires free of charge. Free mounting and balancing will also be included in the service. Owners may contact Cooper Tires directly at 1-800-854-6288 and reference safety recall no. 156. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T010000.
DEL-NAT DELTA Tires: 448 Tires Recalled
A/S Sierradial or National A/S Commando, size 265/70R17; Dot Code of UTIYWHA0112 or UTIYWHD0112. The recall was expected to begin on June 27, 2012 Dealers have agreed to inspect the tires and replace defective tires free of charge. Free mounting and balancing will also be included in the service. Owners may contact DEL-NAT directly at 1-901-775-5002 and reference safety recall no. DN-12-0618. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T012000.
TBC Corporation (TBC): 943 Tires Recalled
Sigma Stampede Radial SUV, size P265/70R17, equipped with dot code UTT6TX60112. The recall was expected to begin on July 2, 2012. Dealers have agreed to inspect the tires and replace defective tires free of charge. Free mounting and balancing will also be included in the service. Owners may contact TBC directly at 1-901-363-8030 and reference safety recall no. 156. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T011000.
Pep Boys Tires: 537 Tires Recalled
Definity Dakota H/T, size P265/70R17; Dot Code UTT6PA7011. The recall was expected to begin on July 9, 2012. Dealers have agreed to inspect the tires and replace defective tires free of charge. Free mounting and balancing will also be included in the service. Owners may contact Pep Boys directly at 1-215-430-9169 and reference safety recall no. 156. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T013000.
TBC Corporation (TBC): 72,938 Tires Recalled
Mirada cross tour SLX and Big Foot/Big O S/T tires, sizes 235/70R16 and 265/70R17, manufactured from January 2009 through January 2011. These tires possess a manufacturing anomaly which may result in a crack or separation in the lower sidewall. If left in service, the crack/separation could grow and rapid air loss may occur, increasing the risk of a vehicle crash.
The recall is expected to begin on July 20, 2012. Dealers have agreed to inspect the tires and replace defective tires free of charge. Free mounting and balancing will also be included in the service. Owners may contact TBC directly at 1-901-363-8030. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T014000.
Lexus Recall – Accelerator Pedal Defect
Toyota has issued a recall of approximately 154,000 Lexus vehicles due to a defect that can cause the accelerator pedal to get stuck while the vehicle is in operation. The pedal in certain 2010 Lexus RX 350 and RX 450 vehicles can get stuck in the wide open position due to its being trapped by an unsecured or incompatible driver’s floor mat. A stuck open accelerator pedal may result in very high vehicle speeds and make it difficult to stop the vehicle, which could increase the risk of a crash and catastrophic injury.
The recall is expected to begin in early August 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Lexus directly at 1-800-255-3987. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V305000.
Volkswagen Recall – Sunroof Defect
Volkswagen has issued a recall of approximately 13,172 Audi Q5 vehicles due to a defect that can cause the sunroof glass panel to break in extremely cold weather conditions. Certain 2012 vehicles manufactured from June 21, 2011 through December 9, 2011 are subject to the recall. Should the sunroof’s glass break while the vehicle is in use, the falling glass could cut and injure the driver or passengers, and increase the risk of an accident.
The recall is expected to begin on August 7, 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Audi directly at 1-800-253-2834 and reference safety recall no. 60B2/L3. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V299000.
SkyJumper
Moderator Emeritus
SW Florida
NHTSA Launches Investigation of Chrysler vehicles
The Office of Defects announced today that they are launching an investigation of Chrysler Group LLC's 2009 Dodge Ram 1500 pickup trucks and 2012 Jeep Grand Cherokee vehicles due to potential manufacturing defects.
2012 Jeep Grand Cherokee: Complaints of power steering hose failures that led to severe vehicle hood fires have sparked the investigation. NHTSA said the reports "allege severe fires resulting in total vehicle loss with the cause as yet undetermined."
2009 Dodge Ram: Consumer complaints of rear differential failures resulting in rear wheel lock-up have led to an investigation that could impact approximately 230,000 vehicles.
An ODI investigation provides a preliminary evaluation to assess the cause, scope and frequency of an alleged defect. If sufficient evidence of vehicle defect is detected, an official safety recall will be issued. Vehicle owners should receive notification directly from the manufacturer if a safety recall is issued.
Nissan Recall – Seat Back Failure Defect
Nissan has issued a recall of approximately 11,076 Juke vehicles manufactured from February 2, 2012 through May 26, 2012. Certain 2012 vehicles may contain a manufacturing defect that can cause the rear seat back striker to partially separate during impact. In the event of a crash, an unsecured rear seat back may result in enhanced injuries to passengers.
The recall is expected to begin at the end of July 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Nissan directly at 1-800-647-7261. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V328000.
Honda Recall – Door Latch Auto Defect
Honda has issued a recall of approximately 172,000 CRV and Acura ILX vehicles due to a manufacturing defect that affects the door latch mechanism. In certain 2013 Honda CRV and 2013 Acura ILX vehicles, if the manual or power door lock is activated while an interior front door handle is being operated by an occupant, the cable connecting the interior door handle to the door latch mechanism may become loose and move out of position. There is a possibility that the cable can move far enough out of position to prevent the door from properly latching. If the door is not fully latched, the door may open while driving or upon impact, increasing the risk of catastrophic injury to the vehicle occupants.
The recall is expected to begin on or about August 16, 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Honda directly at 1-800-999-1009 and reference safety recall numbers S45/S46/S47. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V338000.
Ford Recall – Fuel Line Defect
Ford has issued a recall of approximately 9,320 Escape vehicles manufactured from October 5, 2011 through July 11, 2012, equipped with a 1.6L engine. Certain 2013 vehicles may contain a defect in the compartment fuel line that can lead to a leak. If a leak occurs in the presence of an ignition source, there is an increased risk of a fuel fed fire and/or catastrophic injury.
The recall was expected to begin on July 20, 2012. Dealers have agreed to inspect the vehicle, perform the necessary service free of charge and provide a rental vehicle if needed. Owners may contact Ford directly at 1-866-436-7332 and reference safety recall no. 12S35. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V336000.
SkyJumper
Moderator Emeritus
SW Florida
Defective Tire Recall – BF Goodrich
BF Goodrich has issued a recall of approximately 799,900 Commercial T/A A/S and Uniroyal Laredo HD/H tires (sizes LT235/85R16 120 Q Load Range E and LT245/75R16 120 Q Load Range E) due to a manufacturing defect that can lead to a tread separation. Tread/belt separation of a defective tire while the vehicle is in use can increase the risk of a vehicle crash and catastrophic injury.
The recall was expected to begin on August 6, 2012. Dealers have agreed to inspect the tires and replace defective tires free of charge. Owners may contact Tire Consumer Care directly at 1-800-637-5527. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T019000.
Defective Tire Recall – Kumho Tire
Kumho Tire U.S.A., Inc. has issued a recall of approximately 1,238 Solus KH25 passenger car tires (size 225/45R17), produced from August 21, 2011 through June 23, 2012. Certain defective tires can develop cracking in the sidewall, which can result in rapid air loss, increasing the risk of tire failure and catastrophic injury.
The recall is expected to begin sometime in August 2012. Dealers have agreed to notify owners replace defective tires free of charge. Owners may contact Kumho directly at 1-909-428-3999. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12T020000.
Mazda & Ford Recalls – Stuck Throttle Defect
Mazda and Ford have issued similar recalls of approximately 600,000 vehicles due to a defect that may cause the throttle to stick while the vehicle is in operation. Vehicles may contain a manufacturing defect caused by inadequate clearance between the engine cover and the speed control cable connector. This could result in a stuck throttle when the accelerator pedal is fully or almost-fully depressed. This risk exists regardless of whether or not cruise control is used. A stuck throttle may result in very high vehicle speeds and make it difficult to stop or slow the vehicle, which could cause a crash and catastrophic injury.
Mazda Detail: Mazda’s recall affects 217,500 Tribute vehicles ranging from model year 2001-2006 and 2008. The recall was expected to begin on August 6, 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Mazda directly at 1-800-222-5500, option #6 and reference Mazda safety recall no. 6812G. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V357000
Ford Detail: Ford’s recall affects 423,634 Escape vehicles ranging from model year 2001 through 2004 manufactured from October 22, 1999 through January 23, 2004. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Ford directly at 1-866-436-7332 and reference Ford safety recall no. 12S37. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V353000..
Hyundai Defective Air Bag Recalls
Hyundai has issued a recall of approximately 199,118 Santa Fe vehicles manufactured from April 19, 2006 through July 7, 2008. Certain 2007-2009 vehicles may contain a manufacturing defect that can prevent the airbag from deploying in the event of a crash. A failed airbag can lead to enhanced injuries and catastrophic consequences for motorists.
A recall schedule has not been confirmed. However, once determined, dealers will inspect the vehicle and perform the necessary service free of charge. Owners may contact Hyundai directly at 1-800-633-5151 and reference safety recall no. 105. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V354000.
Hyundai has issued an additional recall of approximately 22,512 Sonata vehicles manufactured from January 24, 2012 through June 21, 2012. Certain 2012-2013 vehicles may contain a manufacturing defect that can cause the curtain side airbags to inflate without cause or impact. An unexpected deployment would be a significant driver distraction and would limit the driver's visibility, increasing the risk of a crash and enhanced injuries.
The recall is expected to begin sometime in August 2012. Dealers have agreed to inspect the vehicle and perform the necessary service free of charge. Owners may contact Hyundai directly at 1-800-633-5151 and reference safety recall no. 106. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V352000.
Toyota Recall
Toyota has issued a recall of approximately 778,000 vehicles due a defect affecting the rear suspension. Certain 2006 through 2011 RAV4 and 2010 Lexus HS250h passenger vehicles manufactured from October 2005 through September 2010 may contain a manufacturing defect that can cause the rear suspension arm to develop unwanted movement and rust, leading to thread damage and eventual failure. Failure of the rear tire rod will cause an abrupt change in the vehicle's alignment and increase the risk of a crash.
A recall schedule has not been confirmed. Owners may contact Toyota directly at 1-800-331-4331 or Lexus at 1-800-255-3987. Additional details can also be found by referencing NHTSA CAMPAIGN ID Number: 12V373000.
Owners are encouraged to contact the National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153) or go to [COLOR="Sienna"]www.safercar.gov[/COLOR] with any questions or concerns surrounding these or any other recalls or safety campaigns.
wolfman96771
Mountain View, Hawaii
2009 Ford Mustang
Ford airbag recalls
My 2009 Mustang has a defective passenger seat occupancy sensor. When no one is seated the airbag flashes code 16. When I fasten the belt on that side still unoccupied, the fault code stops, but the center dash lights up indicating passenger airbag is OFF. My research shows the problem is not unique to my car, and that it has and is an ongoing issue with many cars not just Ford. This vehicle is on the Takata recall for drivers airbag replacement since March of 2015. As yet Ford does not have replacement parts. I believe the passenger seat cushion assembly which includes the bladder, sensor, and ECM should also be recalled. I live in Hawaii (high humidity) and research has shown this to be the root cause of the failures. At this point the vehicle is completely unsafe for the driver and passenger in the event of an accident, the drivers airbag has the potential to cause serious injury or death, and the passenger airbag may or may not deploy or effectively prevent injury or death. Please respond with any direction.
