Hey guys
On the way home from work today, I swung by the car wash to hose some of the salt off of my rig. Well the pressure washer blasted a softball size piece of paint off of my rig right above one of the rear tires (surface rust underneath).
I wanted to take a pic of it for you but my camera **** the bed. My rig is black so I know that makes it a little easier to hide things. Well here is the rig I am talking about:
So let me tell you how I was going to go about fixing it, And if you could tell me if I am way off base or on target would be great (I have painted a few things in my time but a paint guru I am not).
I figured I would chip off any remaining loose paint, sand it down to bare sheet metal, skim coat of bondo, Sand the mud smooth, 2 - 3 coats of rattle can primer, 2 coats of rattle can black duplicolor (or whatever its called), One coat of rattle can clear (just in the new painted area) Wet sand the whole panel with 2000 grit. Buff the whole panel with compound ? Rattle can clear the whole panel. Wet sand and polish the whole panel.
Am I way off base here or on the right track? Any input would be great.
Thanks alot
JIGA
Thanks alot
JIGA
