Livernois
- July 16, 2013
- Dearborn Heights, MI
- 2013 Explorer Sport
Recently we've had the question come up a couple of times of whether or not upgraded rods and pistons are necessary for the 3.5L Ecoboost, here are a couple of photos of an engine that was sent to us for upgrading after suffering a failure. This was a rather high output engine with tune, turbos, etc. As the pictures show, there is a power limit to what the stock parts will handle before failure.
From examining the pistons, rings and bearings there are no signs of this failure being related to detonation or fuel. At power levels above 400WHP you start to get into a territory where the parts are near their outer limits, Beyond 450WHP you get into the territory where it's just a matter of when, not if, the stock rods and pistons will have a failure, because of this a piston and rod upgrade become practically a necessity in order to avoid eventual catastrophic engine failure. Again, while you could probably get away with running the stock bottom end near the 450WHP level, it's only a matter of time before the parts will catastrophically fail.
Below is some information on our Ecoboost piston and rod upgrade. We also offer an Ecoboost head stud kit as well that replaces the factory bolts with upgraded studs. This stud kit allows for greater clamping force to keep the cylinder heads in place under high loads typical of modified Ecoboost engines.
LIVERNOIS MOTORSPORTS AND ENGINEERING ECOBOOST PISTON AND ROD COMBO
Livernois Motorsports Exclusive EcoBoost Connecting Rods
I Beam design
4340 Billet Material
ARP 2000 Rod Bolts
Compatible with factory style bearings and crankshaft (must verify clearances)
Requires no modifications to work, just balance, and machine for proper clearances
Livernois Motorsports Exclusive EcoBoost Pistons
2618 Forged Material
Thicker crown and skirt for increased power capacity
Improved ring land design for better durability
Production compression ratio standard (can custom order in different compression ratios)
Crown coated with ceramic heat barrier to improve piston durability
Skirt coated with a molly based anti friction material to improve skirt wear
Package Includes: Billet Rods, Coated Pistons, Piston Pins, and Rings
Click here for more information on our Ecoboost performance packages and products or to place your orders as well.
Attached are some photo's of some recent builds, as well as some shots of the machine and engine shop.
I Beam design
ARP 2000 Rod Bolts
