I guess i should have been more specific though, I meant a lunchbox locker, not a full carrier locker.
Oh ahha ok. Look for...
Powertrax Lockright - Basic Lunchbox locker
Powertrax Noslip - Better lunchbox locker, not sure of the exact differences between the lock right and the NoSlip. But i do know that the NoSlip makes a lot less noise. And the obvious price difference (+$100)
Aussie Locker - Basic Lunchbox locker. Newer in the industry, i havent heard much about them, ive been trying to decide between these and the NoSlip for my D35 myself.
Detior EZ locker- Basic Lunchbox locker/ A lot of people question the machining of these lockers, they look kinda rough, but they get the job done just as good as the lockright
What do you mean by side gears? The ring and pinion? Forgive me, I probably know more than most about axles but I am by no means an expert. Would your comment about switching side gears apply to a lunchbox locker? I'm guessing not, because it can go in either way.
haha yes, you will be replacing the Side Gears (and the spider gears) when you put in a 'Lunchbox' locker. They are the gears on the 'side.' The spider gears go in the middle. These are the gears in the center of the carrier.
mjma said:
I know, A lunchbox locker behind a 6 cylinder in a dana 35 rear is a recipe for broken shafts but from what I've heard the TTB D35 doesn't have the strength problems that the dana 35 rear does. Would you agree?
Well the problem with an Automatic locker upfront is the fact when you turn your going to be getting quirks, bangs, and possibly broken shafts. If you do 'really hard' wheeling, or you find yourself fighting slippery rocks in the utah mountains then you probably want to advise against it. But if you are like me and just like turning up mud and pushing your luck on the mediocre stuff then a lunchbox locker should be fine.
Heres the thing about the Dana 35 rear axle and the Dana 35 Ford TTB. The Jeep D35 has standard cut gears, while the TTB D35 is reverse cut. Reverse cut gears are noted to be stronger in a front axle, making the strength Dana 35 equivalint to a Standard cut Dana44 (rear axle?). The TTB Dana35 is pretty Darn strong. It could have been built stronger with a Iron or steal housing (and definatly a lot cheaper then aluminum). Although rare, it is possbile to crack and destroy the aluminum housing of the TTB D35, but more than likley that will never happen.
The D35 is definatly not as strong as your rear axle (Ford 8.8) but it balances out pretty good.
