Re: LOCKERS ARE OK IN THE RAIN!
Hey; Guys I just wanted to tell you about my locker.All the lockers that are out there are good and all but the need for all that spent money is just really crazy.And as for the labor that is just a total joke, sure taking the truck to a shop is the right thing to do but lets get real.Taht 1000$ bucks could be much better spent on a winch or some bead locks.O.K. here is the deal,first the back lash on a 8.8 rear end is so damm sloppy any clown can put the diff back in with no problem.As for the locker just put the rear of the truck up on jack stands pull the rear tires.Next take off the diff cover use something to catch that nasty gear oil,Pull the c-clips on the axel shafts the pull the axels out about 10" so that they will clear the diff.Remove the 4 bearing bolts and drop out the diff be carefull that sucker ain't lite.Now clean it down with break cleaner and take it to a good welding shop and I mean a good welding shop not your buddy with the 110 stick welder!The shop will charge around 40$ Make sure you stick something inside the axel shaft holes th keep out any slag from welding.Clean everything again and put it back together. It is that easy really it is I've done 3 this way and none have ever broken.This can be done in one day no problem and as for driving I really do not see a diffrence I have 35 swampers on mine and I drive it to work every day and pull my trailer with it.Mine has been in my expolorer for a year and no problems.And seeing as how I live close to Attica it gets some real wheel'n time put on it.So dont be a shy step up and get some real traction and for under 50$bucks.If you have questions just e-mail me at klove@csinet.net Good luck.
