  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Locking Fuel Cap Part Number
scotch4ever
Cincinnati, OH
2004 Ford Explorer XLT
I drive a 2004 Ford Explorer XLT, 4.0 VS Gas and have had a heck of a time finding a locking fuel cap. Every time I do any kind of search with Motorcraft or an auto parts re-seller of Motorcraft they give me the part code :XU5Z-9030-HC. It does not fit as that part does not have any grooves like a screw just a plug with 3 equally spaced ridges running the length of the gas cap stem.
Any thoughts? Has my fuel receiver been modified?
scotch4ever
Cincinnati, OH
Many thanks for the reply. It is just weird that the fuel cap design for the Ford explorer will not fit my vehicle. There must have been a modification made by a prior owner.
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
I'm fairly certain I bought my locking gas cap at Advance Auto Parts for my 2005 Explorer XLT, if I remember right. I bought it approx. 3 years ago and have had no problems with it. I'll double check tomorrow and take a pic of it as well if need be (let me know), but I think it was made by "Stant". They should have a chart at Advance to check what year/vehicles the locking gas caps fit to.
R Doors locking everytime brake pedal depressed Stock 2002 - 2005 Explorers 0
3 locking itself Stock 2002 - 2005 Explorers 2
S Locking in and out of PARK Stock 2002 - 2005 Explorers 3
2 central locking/door ajar problem Stock 2002 - 2005 Explorers 4
S Explorer hatch locking/unlocking while on Stock 2002 - 2005 Explorers 1
X Intermittent locking with the remote Stock 2002 - 2005 Explorers 0
K $x4 and Locking Diff question Stock 2002 - 2005 Explorers 13
V Locking the camshaft - timing issue Stock 2002 - 2005 Explorers 5
S Anti Hijack door locking Stock 2002 - 2005 Explorers 3
S Alarm Sounds Off after Locking Vehicle Stock 2002 - 2005 Explorers 9
J Locking doors with engine running 2005 Stock 2002 - 2005 Explorers 5
D ABS light is on with the brakes locking up. Stock 2002 - 2005 Explorers 4
T Driver door not locking Stock 2002 - 2005 Explorers 1
C Automatic locking/unlocking problem Stock 2002 - 2005 Explorers 16
T Want horn to beep when locking door. Stock 2002 - 2005 Explorers 5
T Auto locking delay problem? Stock 2002 - 2005 Explorers 3
S fuel leak after fillup now stalling while driving Stock 2002 - 2005 Explorers 3
Number4 Solved ‘04, ‘05 direct power to fuel pump Stock 2002 - 2005 Explorers 2
Number4 Gas leak at front of fuel tank Stock 2002 - 2005 Explorers 14
D Fuel tank Pressure Sensor Stock 2002 - 2005 Explorers 0
W Bank 1 Not Burning Fuel Stock 2002 - 2005 Explorers 3
J 2002 explorer XLS Flex Fuel Turns Won’t Start Stock 2002 - 2005 Explorers 1
R '04 4.0L Fuel Tank vent clog? Stock 2002 - 2005 Explorers 0
R 2005 Explorer 4.6 P1237 and P0191 Fuel Pump Stock 2002 - 2005 Explorers 0
T Does it matter how the fuel lines are connected on 3 line fuel filter Stock 2002 - 2005 Explorers 17
A Help! Fuel pump. Stock 2002 - 2005 Explorers 0
R Fuel gauge/light issues Stock 2002 - 2005 Explorers 4
T Solved Fuel pump power issues after transmission swap. Stock 2002 - 2005 Explorers 5
A HELP! 2005 Ford Explorer Fuel Pump ???? Stock 2002 - 2005 Explorers 15
D 2002 Explorer Won’t start, clicking after fuel filter change Stock 2002 - 2005 Explorers 10
B 4.0 SOHC misses on Cyls 1 and 2 after replacing EGR&Fuel Press Sensor Stock 2002 - 2005 Explorers 6
2 Fuel Pressure Sensor Tourque Stock 2002 - 2005 Explorers 0
Number4 Broken hose to fuel tank system Stock 2002 - 2005 Explorers 2
T Could someone pls post the correct place to cut a hole for fuel pump access Stock 2002 - 2005 Explorers 15
R O/D light on and problem with Fuel Pump Stock 2002 - 2005 Explorers 0
J Vacuum issues with 2003 Explorer (K Motor Flex Fuel) Stock 2002 - 2005 Explorers 0
Y Replace fuel filter with aftermarket Stock 2002 - 2005 Explorers 0
G fuel pressure release?? Stock 2002 - 2005 Explorers 4
L Flex fuel motor Stock 2002 - 2005 Explorers 3
A Fuel vapor smell 05 Gen3 Stock 2002 - 2005 Explorers 1
F Cranks and Won't start? Flooded and Fuel in Oil? 2005 Ford Explorer 4.0? Stock 2002 - 2005 Explorers 7
J Fuel pump Stock 2002 - 2005 Explorers 1
M 2002 EB fuel pump wires to 3 pin connector? Stock 2002 - 2005 Explorers 0
T Odd Fuel Level Sending Unit Problem Stock 2002 - 2005 Explorers 2
M 2002 EB Crank/no-start vinE 4.0 SOHC fuel pressure puzzlement Stock 2002 - 2005 Explorers 5
B 04 fuel filter Stock 2002 - 2005 Explorers 2
R 2002 Ford Explorer XLT 4.0 Fuel Pump Replacement. Guide For Cutting Floor? Stock 2002 - 2005 Explorers 0
C Rough idle and high bank 2 fuel trims Stock 2002 - 2005 Explorers 2
N Fuel tank needed for my 2005 Explorer Stock 2002 - 2005 Explorers 9
C Crank, wont start, no fuel pressure Stock 2002 - 2005 Explorers 1
Similar threads
