Originally posted by Lamah
=/ i dont want to have to hop out and turn the hubs when i'm stuck in a snow bank, i'd rather pay extra later
Okay, think about that. You can get manual hubs that WILL NOT BREAK (disclaimer: under nonextreme 4+ trail application) but will require you to hop out and turn the hub, or you can keep replacing the MUCH-more-expen$ive auto hubs that WILL BREAK and leave you "stuck in a snowbank" per your own words. The fact that you have to pay extra later means you had to replace those autohubs which means they FAILED on you and left you STRANDED - usually, per Murphy, at the worst possible moment.
If you have an accountant mind like me, sometimes it helps to consisely clarify a situation in order to help visualize a decision:
Autohubs = weak & expensive = spend night in vehicle in blizzard.
Manual hubs = strong & cheap = get home.
Ask anyone on this board with any experience with those hubs, and you will hear dozens of stories about how the autohubs failed in simple beach sand and nonstressful applications. They are weak, and will fail when you need them the most.
I'd rather have to hop out of my vehicle for a few seconds to engage a much less expensive (but much stronger!) hub than spend the night in a stranded vehicle in a freezing blizzard for the privilege of maintaining the very same much more expensive autohub system that left me stranded where the cheaper one would have not failed on me in the first place.
This board now has over 3,500 members, many of whom have extensive (and expensive) experience in this area. I can confidently say that
none of them will join this discussion to suggest that you keep the autohubs. I would suggest that would be a fairly strong hint to get the manuals.
[Edited by GJarrett on 11-03-2000 at 10:55 PM]
