long travel susp. for 2000 exlp. | Ford Explorer Forums - Serious Explorations
smamales
salt lake city ut.
2000 limited
I would like to know if a long travel suspension is avl. for a 2000 or a good lift kit and not a superlift thank for your time
No SIr. Your best bet is to swap a solid axle iin up front.
You might try searching here as there is alot of information.
awd,i would like to know if the superlift is any good. I would like a prerunner set up, or something close.
i've got a 2wd, it's alot easier with a 2wd and i run a uniball setup from mcneil offroad, but dixonbrosracing.com just came out with a torsion bar 4wd setup, but going the longtravel way is a bit pricey, about three or sometimes even five times more expensive then bolt on kits.
Thanks guys i'm going to order there kit .that thing is sick :thumbsup:
