Looking for 2020 Explorer ST 21" Wheel Specs
JacobZ06
Location
Vancouver
Vancouver BC
2018 Platinum
Have an Atlas Blue ST with Street Pack 21 inch wheels on order. Wondering if anyone knows the OEM wheel specifications: Center bore, bolt pattern, rim width and offset. I would keep my aftermarket Touren 20 " wheels from my 2018 Explorer if the specs are the same.
Thanks for your help.
Jacob
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
neocvera
Texas
2020 Explorer ST
I know it doesn’t help but it gave me a reason to post this image. 21” confirmed by my phone!
CaptRapt
Great Falls, MT
2020 Explorer ST SW
If someone popped off one of those 21”s I bet there’s an “et” stamp with the specs including offset.
North Olmsted
2018 Explorer Sport
Most likely they are a 21x9" or a 21x9.5" wheel with the ford standard 5 x 4.5" (5 x 113.4 mm) lug pattern.
CaptRapt
Great Falls, MT
2020 Explorer ST SW
I think he is looking for the more detailed specs (offset/backspacing) of the wheel. I can’t find those specs either after looking around a bit. I wanted to shop some aftermarket 20” wheels. I think the ST lowered on some meaty 305/20s would look bad ass. Go ahead and drive home the better handling of the explorer over most competitors.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
BrianCanada
Edmonton, Alberta
2020 Explorer ST
I did more digging and found multiple data bases that list the 21" wheel with a 63.4 hub bore. Looks like themishmosh has confirmed 70.5 hub bore with his 18" winters.
peterk9
Staff member
Moderator
Callsign
VE3
You said you measured the spare, do you have a 2020 Explorer?
peterk9
Staff member
Moderator
Callsign
VE3
Bstard2001
Long Island, NY
2020 Explorer ST
Hello all..can anyone recommend a set of black locking lug nuts for the ST with Street Pack....thanks in advance.
North Olmsted
2018 Explorer Sport
It depends on what thread size the 2020's have on the lugs, if they still have the old 1/2-20 then use mustang lug nuts from 05-14. If they use the newer 14mm lugs then use the 15-20 mustang ones. You can buy either one from www.americanmuscle.com
