Ford Explorer Forums
Hey all,
I am looking for advice to bolt a skid plate to the front cross member on my 95 EX. Been searching, and found welded, and bottom mount styles.
It will be bolted to a cross bar I attached between the frame rails up front, but for mounting it in the rear I am asking for advice. I don't want to weld it, I want it to be removed easy enough for maintenance.
I want it to the front of the cross member so I dont have to worry about dragging the bolts on the underneath. Pictures are much appreciated :thumbsup:
So...how to attach it? Drill the holes, and is that safe? Will it weaken the cross member?
Can the cross member be tapped for a bolt? I dont see how I can get a washer & nut inside it.
Try to use the C-clips for the bolts? (These will require a 2nd hole drilled.)
The skid is 1/4" steel plate. I have yet to bend the rear tab for cross member attachment. Just making sure it can be done to the front b4 it is bent.
Thanks in advance. I have been wanting to get this done for a long time now.
