good suggestion with the cheap alternative fo the autozone shackles..but do you like to frabricatE? kuz the only safe way to use summa those things is to weld up a support strut to connect them the way the warriors and most shackles are made..they will bend, and are just all around crappy..for the money get the strong, welded, thick walled steel, powder coated warrior shackles..add a leaf for me was worth it, but a lot or work, and work i just didnt expect..i did a lot of research too, but i couldnt get the stock shackles off without grinding and cutting them, and my bushings were thrashed..so regaurdless really of wut you do..i suggest replacing the bushings with polyurethance bushins while your down ther..and while your at it..it was really beneficial for me to paint the leaf packs and a lto of the areas i could get to down ther too..a nice black protective enamel is all it takes..to improve look, life, and stop rust..i say get a skyjacker or rough country 2in lift coil up front, add a leaf by procomp and a warrior shackle in the rear, drop all the partsin the rear, paint the the leaf packs, and get new hardware for most of the mounting bolts, give yourself a few days for shipping parts u didnt expect to by, and for painting things, sand and paint the leafs, the stock shackles if you reuse em, paint the shock mounts too and the wall of the chassis that you can see from the wheel well..you will be very happy with the outcome, and it will look 100 times better..add a leaf if a lil extra work then boltin em right up..but like i said, worth it for the money..and really, look up that step by step on this forum to help you out..i think thers a step by step for the warrior shackle too even tho its relatively simple..you'll be able to slide 31s under easy..i'd go even for a 1150 if you wunted..look pretty sweet..perform even better..get them polyurethance bushings for under ther too..if your over 140k, GET THEM, will improve handling, and life, and look, and youll just be happy you did it while u had eveything apart.. 50 bux maybe off summit..you can use the stock alloys, but i like the cragar soft 8, chrome or black..and ther a few other cragar wheels under 55 bux each that are reallly sweet..so chek them out..(summit)
