LostNtheMud
- December 2, 2002
- Jacksonville,NC
- 93 XLT
This is gonna be a little long winded, but I am quite confused as to what's up with the a4ld in my 93 ex. The symptoms are as follows: when it is cold out, the tranny will not upshift from 1st gear until it has been rode at 4000 rpms for approx. 1-2 miles. Not good! What I am able to do is manually shift from 1st to 2nd with no problems. If I do this for a couple of miles, then put it in OD or D it will shift about normal, maybe 200 or 300 rpms above the normal shift point. The confusing part is that once it shifts the first time, it works fine as long as it stays warm. If it sits for a couple of hours on a cold day, I have to go through the whole manual shifting thing again. I did a fluid and filter change this weekend and found metal shavings in the pan, as well as the tranny fluid being almost gray(again, not good!). I am sure something internal is disintegrating, but I don't understand why after the first shift, the tranny works just the way it's supposed to. I would suspect the vacuum advance if it didn't work fine after the first shift. I am almost clueless as to exactly what the torque converter does and I am wondering if this could have something to do with it. Any and all help will be appreciated. If anyone out there knows any diagnostics tricks I can use to narrow down the possible problem, all suggestions are welcome.
