stephan325i
- October 6, 2007
- Oshkosh Wisconsin
- 1985 Bronco II, 2.8, 5spd
So heres the deal guys...... As much as i hate to say it, it might be time to let the old dog go.
I have a 1993 XLT with 209,000 miles on it. It has new brakes all around and the only thing that is wrong with them is that the front rotors are warped a little from a angry drive i took. (like two days after i put them on...dam it):thumbdwn: The engine runs great, with a little tick, maybe rockers or worn cam, who knows. BRAND new water pump, just put it on last weekend. New servo O-Rings, new trans pan gasket. Shocks are only like 3 years old at most. Everything works, 4x4, trans is strong and shifts smooth. A little engine oil leak off the back corner of the right bank valve cover gasket and maybe off the oil pan. NEW battery, again just put in last weekend, spark plug wires and plugs were replaced last fall. I think the control arm bushings are worn out. Any ways.... heres the bad stuff...RUST. As most of you 1st gen owners probably know, they rust, alot. There are basically no lips on the rear fenders starting to rust up into the body a little, rust above the gas fill, through, but not bigger than a quarter. Rockers are basically gone from about the door split to the dog leg. bottom of doors have a little rust and the bottom of the trunk lid.
So all that said, what do you guys all think of a price for it if i did sell it? This is a big IF. And IF i do sell it, im happy to say i am sticking with Ford!!! But what ever i can get out of the X will help with payments on a new 4x4.
Thanks again in advance!!! Oh and if any of you want to buy it.... its for sale hahaha!!!!
And looking at these pictures i remembered that there is the spare rim on the back passenger spot now, the rim is cracked..... which sucked.
I keep thinking of more.. new windshield, apparently the arms that come down to stop you from driving across a opening draw birdge are there for a reason... to break your window for no apparent reason... haha
