Pepou812
- April 11, 2014
- Lafayette,louisiana
- 2004 ford explorer 4.0L
2004 ford explorer sohc 4.0 L cam replacement torque specs for the cam shaft cap bolts and for the left front upper timing chain gear bolt also left rear upper timing chain gear bolt i dont trust the book i have i've already snaped one bolt off in the cam. Please help. Thank you (I'm at work so I'll check back as often as I can again thank you).
