Yeah buddy now you are talking my language!! Nothing like a lifted Gen I
try searching 94 ranger
Skyjacker® Suspension Lift Kits provide a smooth, comfortable ride, while responding to on or off-road conditions.
skyjacker.com
Skyjacker has about 20 options for you
James Duff makes very good stuff
Are you looking to lift your Ranger for the trail or more tire clearance? Learn more about the selection of lift systems for your ’83-’97 Ford Ranger.
dufftuff.com
Play with the big boys out in the desert:
camburg.com
86-97 Ranger & 91-94 Explorer Mid-Travel suspension kit offers a 4" Lift and Deaver leaf springs for the rear. Ranger, Explorer, and Bronco ii 1986-1997
solomotorsports.com
Autofab makes a long travel dana 44 conversion kit
Covert your 1983-97 Ranger 4×4 to the F150/Bronco model 44 front end. Increases track width 8 inches to match with an F150 rear end. More stability, bigger brakes, hubs, and axles. A bigger 1/2 ton wheel bolt circle allows you to basically create an F150 with your Ranger. Must use fiberglass...
autofab.com
Just know that the explorer rear leafs go under the axle, ranger rear leafs go over the axle, so while the front lift parts for a 91-97 4.0 Ranger will work on your explorer you will need to do something different in the rear to match the front
Rear lift options for gen I explorer:
shackle (1-2")
add a leaf (yuck)
spring over (5")
How high do you want the truck? What will you use it for? What is your budget?
As you can see with that front end the sky is the limit
