magneti
- March 11, 2010
- '97 Explorer v8
had a 2005 dodge 1500 just up and die on me. never again will i own a dodge. first and last.
anyhow, needed something quick for work and came across the explorer. has 130k miles yet surprisingly drives better than the dodge or any toyota (4runners/tacoma) i owned before.
turns out it was a rich womans vehicle who then handed it down to her daughter whom i bought it from. one owner and had all the receipts from work done in the glove box. its a v8 5.0.
i see they changed the oil every 3,000 miles from the day they drove it off the lot til now. i changed the oil last weekend and it was impossible to see the oil on the stick as it was as clean as could be. i suppose i should learn a lesson from more frequent oil changes and constant maintenance that they did.
after checking the records further, i noticed it had most of the miles accrued in the first 6 years. over 110 then with only 20 over the last 5 or so. the last couple of years it only had about a thousand i believe. so i guess im worried about leaks and such but so far so good.
first tank of gas i checked the mileage and got 16 in the city. not bad for a 13 yr old ford.
the tires are stock and had 4k miles, the tranny and engine are original.
work done that i can verify is all minor--radiator hoses, thermostats, belts, brakes, O2, plugs. nothing major which worries me since it all could come crashing down.
its all electric along with the driver door keypad and everything works. this probably surprises me the most. inside is super clean. i must admit, ive only owned one ford before but went from simply getting a work truck/suv to enjoying this one more than i expected.
ok enough rambling. just enjoying the forum and have become an explorer enthusiast it seems.
oh and i was going to change the plugs and wires but saw they only have about 10k miles on them but that was done a few years ago so im undecided. from looking at their placement it looks like it could be a ***** of a job with many busted knuckles.
