Boywonder629
- September 26, 2012
- Davison Michigan
- 1998 Mercury Mountaineer
So after waste money on pads,rotors, brake fluid flush and a master cylinder i found the cause of my soft pedal, actully i more stumbled apon it well bleeding the master cyl. I noticed the whole brake booster moving well the pedal was pumped so going under the dash to see if the bolts were loose discovered each to be about a quarter to half a turn loose, this little amount made a huge difference in the feel of my brakes, so learn from my mistakes dont waste your moneycheck the bolts. I guess on the bright side im not gonna need master cylinder, pads and rotors or new fluid anytime soon
