Evicerate
- November 16, 2003
- KY
- 1994 XLT
I've checked the other threads and all of the guys with similar problems seem to have body lifts.
My 1994 X is stock height and the steering is getting squirrelly. The steering wheel is also ****ed a little to the left when the X is going straight.
I've checked the tie rods and they're fine. Bearings are good too as they were replaced when I put new rotors on in July. Tightening the steering gear corrected the slop for about 2 days. However, when the steering wheel is locked I can grab the steeing shaft under the hood and twist it about 5 degrees back and forth.
I am assuming the slop, the ****eyed wheel tilt, and the shaft play are not normal. Does anyone have any input on what's wrong? Is it worn U-joints on the steering shaft, a worn out gearbox, or something else? any helf is appreciated.
