Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
In the past few months I've noticed that when I take longer road trips I find that my expansion tank nearly empties out. If I drive it around town, back and forth to work I don't lose any coolant. In the past I've changed out my thermostat housing twice because coolant pooled on top of my engine. The latest thermostat housing I'm using is steel and the top of the engine is bone dry so I know I'm not losing coolant from the housing. I changed my radiator out 1.5 years ago when my old one started leaking, the new one is a spectre premium and bought that because I was led to believe it was good quality. The radiator being new I wouldn't expect the coolant to be leaking into my transmission from there but you never know and I'm going to look there next. The inside of my car doesn't smell funny and the carpet is dry so I don't think the heater core is leaking. I suppose I somehow could have blown my head gasket but my vehicle has never over heated on me and I'm always good about the fluid changes and maintenance, I owned it for over 5 years. Is there something else I'm overlooking that could also be the culprit for my coolant loss? Wouldn't there be ATF in my radiator mixed with the coolant if the AT cooler started to leak? I'm at a loss here
. I'll also mention I have been having some worse 2nd to 3rd gear shift flares but my transmission has always been kind of funky shifting through those gears but I don't know how a transmission reacts with coolant in it.
