Loss of power & Low oil pressure light | Ford Explorer Forums - Serious Explorations
bolton2000
BLANCHARD, OK
2012 Explorer Limited
My 2012 Explorer with the 2.0L gives a low engine oil pressure warning when it's really hot outside (like 100 degrees) and the vehicle has been running for a couple hours. The other day I was driving it on the interstate and I lost power suddenly and the warning light pop up. We went and ate at a local restaurant and after that, I was able to make the 20 mile drive home without issue. This past Friday similar thing happen. I can restart the engine after it happens but it will not stay running long. Oil level is good and oil is freshly changed. I have replaced the oil pressure sensor with no luck. The engine has 173,000 miles on it. Any ideals of what may be wrong?
Welcome to the Forum. :wave:
It could be the oil pressure sensor as mentioned in other threads but the loss of power is different. Did you check to see if there are any trouble codes stored?
I did this afternoon and the code was P0087 which has to do with fuel pressure.
