socci
- October 26, 2011
- Coventry, RI
- 2000 Explorer XLT
So started my truck and I felt a pop in the brake pedal and then lost pressure in the pedal. The pedal will very easily go to the ground, but it still comes back up freely and the truck will stop when the pedal is all the way down. At first whenever I stepped on the pedal there was a whooshing noise (loud) that sounded like it was under the backseat drivers side. I shut the truck off, was able to build up brake pressure just fine, but once it started again the pedal lost pressure but this time the whooshing sound is gone. My fluid reservoir drained as soon as this happened. It did not fully drain, but the fluid is now very low. I cannot find a leak anywhere though. Any help is appreciated, I need this fixed asap.
