PHOTOGRAPHER
- December 25, 2012
- Houston, Texas
- 2013 Ford Explorer
So I have had my 2013 Ex XLT since January and have been experiencing some issues with Sync using my iphone 4s.
I am planning on calling Ford with some questions but I thought Id run some of them by you guys to see what you think or if any of you were having similar issues.
-Phone not syncing for calls properly: I have had several times where I get in the car and my iphone reads "sync" but nothing is coming out of the speakers so I have to quickly switch to the handset before i lose the call.
-Phone not syncing to bluetooth music stream: Several times recently when I have my iphone connected via bluetooth and I try and switch to the bluetooth audio feed it does not want to connect. It says connecting then eventually just cancels and goes back to whatever source I was on. Doesnt matter if I play a song/audio on my phone first or not. It would be nice to know if there was a proper procedure in order to make it work.
-Maps and camera issue: This just happened today but it seemed like my navigation was lagging way behind and at one point my backup camera was not working or was lagging. Things have just not worked all the time like the bluetooth but today was the first time the system actually felt slow or laggy.
I use my iphone 4s and just want to be able to hit the BLUETOOTH STREAM source and have it stream wirelessly without issue. I like to use Spotify but Ive tried it with other sources of audio on the phone such as the actual music app and it still refuses to connect often.
I also just want the calls to actually come through the speakers when I have SYNC selected on my iphone.
A lot of times regardless of if the call is actually synced or not, after the call has been ended via my iphone the sync system thinks its still in the call and will keep the music muted. The only way to fix this is to turn off the system and back on again via just turning the radio on and off.
Any help or insight would be great.
