Low idle, 411 and 412 codes KOER | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Will Presley
Memphis/Nashville, TN
1994 Eddie Bauer 4x4
Hey, folks! I have '94 Eddie Bauer 4x4, 4.0L OHV. I recently fixed a bunch of air intake issues that were causing a lean condition. The truck ran great for a while, but now it's running rough again. I did an idle relearn procedure, which helped for about a day. Now the truck is running with a slightly low idle, and it's running rough. No check engine light, but I did the self test and passed KOEO, though I got codes 411 and 412 for KOER. I've checked for vacuum leaks and can't find any. I've replaced the IAC about 5 times, so I doubt that's the problem. Any ideas? Thanks!
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
Clean out the throttle body. Your IAC may be working, but if the passages are clogged, it really can't do much.
Centaurious
Pensacola FL
1994 Explorer Sport
Seconded! While you are at it pull the EGR Valve and ream out the passage behind it, It actually is about 1/2 inch in diameter.
