Creager
- October 11, 2004
- Charlotte, NC
- '92 Sport 4x4
Heres the deal,
In the past i had issues with my engine's RPM surging downward towards 500-600 rpm, sometimes equating into a stall. Replacing the IAC with a new motorcraft unit seemed to fix the surging part, but the RPM at idle still has a tendacey to get low once the truck has warmed up.
Following iginition, rpms raise as high as 1400 (This engine has lots of mods, i figured this was somewhat normal, although it never went this high with the old IAC (1200 most). But the old one caused the RPM to surge like crazy, it just may have never given the engine a chance to idle in open loop at 1400rpm)
After approx. 15-30 seconds, RPM slowly decreases to 1200, then 1000, then finally 750 where it stays until warm. Once its warm, it wants to idle (smoothly) at 600. Which is a little low for me...
MAF is clean, ive tried swapping between a PRO-M maf and the stock ford unit, both dont seem to make a difference.
Fuelpressure (at the rail) rises to 35-40psi when turning the key before ignition, drops to 28psi at WOT. Idles around 30 psi
Compression is an even 195-205lbs between all 6 cylinders
No obvious vaccume leaks, PCV system may be a little suspect. But i've never had a vaccume leak that caused RPM to drop?
The comp cam definatly idles a little rough, but it still shouldnt drop low past 750rpm. Using the a little throttle levels out the RPM.
ideas? New IAC junk?
