low oil press | Ford Explorer - Ford Ranger Forums - Serious Explorations
low oil press
john93rangerstx
warwick ri
93 rangers stx
i have low oil presor when i first start it up in the morning and it ticks bad the when it warms up its fine and then the rest of the day it fine i have changed the oil two time this week thinking i had a bad oil filter any idears is a 4.0 v6
shaggymane
topeka, kansas
91 navajo
If the rangers are the same set up as Nav's and Exp's then the oil gauge is not really a gauge. It's just an off/on switch.When it's on the gauge goes to the middle. When the sender is going bad the needle will lag or show less oil pressure. I had the same question, same problem with pressure drop. New sender fixed the *low oil pressure*.
If you want a good reading you'll have to round up a mechanical gauge.
eta The ticking could be injector noise. Run a good fuel system cleaner though it see if there's a change
