KGauger
- November 28, 2006
- Carlton, GA
- '91 Mazda Navajo
I picked up a '92 Explorer that had low oil pressure problems. I tried about everything and finally decided to have the oil pump and screen replaced. I took it to a repair shop and they pulled the engine, replaced the oil pump and oil screen, the rear main seal on the engine and changed the oil and oil filter. I drove it about 50 miles and I am experiencing the same problems. Tbe oil pressure will drop if you accelerate but may come back up in you let off on the gas. Also if you turn the engine off for a few minutes and then start the engine again, the oil pressure may come back up. The original oil screen was clogged but I can't believe a new oil screen is clogged atfer 50 miles. Any ideas?
Thanks,
Ken Gauger
Thanks,
Ken Gauger
