Low Washer Fluid Warning Stuck on | Ford Explorer - Ford Ranger Forums - Serious Explorations
Luke1975
Harrisonburg, VA
2011 Explorer Ltd
First post here. Found site Goggling to find info about this issue.
I took my 2011 Limited to the dealer in December 2012 after the Low Washer Fluid Waring and stayed on after I filled the tank to the top with fluid. They confirmed the light was not working properly and replaced the washer tank. (see photo of service ticket)
Last week the light came on again so I fill tank and now the light is stuck on again. Does anyone know where is sensor is that tell the Explorer that the fluid is low. Seems odd to me that 2 tanks have went bad in less than 6 months.
Anyone else hear of a bad fluid level indicator?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Luke1975.:wavey:
I don`t recall reading any other posts with this issue. I would guess that the sensor is somewhere within the fluid container itself.
peterk9
Staff member
Moderator
Callsign
VE3
I came across the following photo that shows the washer tank and you can see where the sensors are located. I guess that explains why they had to remove the inner fender. Hope that helps.
Luke1975
Harrisonburg, VA
2011 Explorer Ltd
That is a good photo of the washer bottle Peter. I an going to take it back to the dealer when I get a chance. I'll post an update after that.
FordService
Official Ford Rep
Dearborn, MI
Hi Luke1975,
Let us know what you hear from the dealer. If you need my assistance, send me a PM with your information and I'll check out your case. I'll need your VIN, dealer, mileage, daytime phone number, and full name.
Thanks!
Crystal
Luke1975
Harrisonburg, VA
2011 Explorer Ltd
Hi Luke1975,
Thanks!
Crystal
Thanks for your offer Crystal. The crew at Harrisonburg Ford in Harrisonburg, VA is usually helpful but will let you know if there is any problem.
FordService
Official Ford Rep
Dearborn, MI
Keep me posted, Luke1975. I'm sure the fine folks at Harrisonburg Ford will take great care of you. :)
Crystal
Luke1975
Harrisonburg, VA
2011 Explorer Ltd
Just got my Explorer back. They replaced the washer level sensor and it is working now.
tr808
Cincinnati, OH
2013 Ex Sport
Low washer fluid sensor...
Is it really possible that a loaded, near $50k vehicle sold in 2013 lacks a "low washer fluid" sensor? Ran out of juice in my Sport the other day... Blew my mind.
It's a regression of sorts - I'm pretty sure my '01 Ex Sport had this, and it didn't even have automatic transmission! :)
Obviously not a big deal, but seriously Ford - details count.
(Of course, if there *is* supposed to be a sensor & mine just isn't working... lemme know!)
peterk9
Staff member
Moderator
Callsign
VE3
I would assume that since the non-Sport model has the sensors, that your would have as well. Perhaps they aren't functioning properly.
tr808
Cincinnati, OH
2013 Ex Sport
Wow, not sure how I missed this thread; thx for moving mine.
So what's the official word? Does the Sport have a fluid sensor?
peterk9
Staff member
Moderator
Callsign
VE3
I just checked the online 2013 Owner's Guide and unless there is a different one for the Sport, the answer would seem to be that it does have sensors.
Page 117 (Instrument Cluster) shows an indicator picture for the low washer level sensor warning with the following;
Low washer fluid (RTT)
Illuminates when the windshield washer fluid is low.
RmT
Ford Explorer XLT
Does anyone know if there is a code that can be reset to clear the light? I'd like to make sure I've tried all options before replacing the sensor. Thanks.
2015 XLT 3.6L
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum. :wave:
I would think the issue is likely with the sending unit in the washer fluid container. Is the pump working?
RmT
Ford Explorer XLT
Yes the pump works fine and the tank is full. I was hoping there was something else that could be done before replacing the sensor. Thanks.
G8orFord
LAUREL HILL
2016 Explorer Sport
You can unplug the sensor if you just don't want to look at the light. At least that worked on my '07 Expedition.
