budwich
- May 4, 2005
- Ottawa, Ont
- 96 XL
I have a lower ball joint problem (both sides... inside tire wear). No major steering issues just basically wear on the inside of both tires. Alignment guys "look / see" says both lower ball joint have "looseness".... ok no problem. I read thru the great write up in the section on replacement, doesn't look like an issue. Should be doable with a few rented tools as I have most of the other stuff. My "silly" question is based on what I see in the write up, and not knowing much about "alignment adjustments", IF I do both lowers, is it "imperative" that the vehicle has an alignment there after????.... assuming everything goes back together the way it came off... ie. tie rods are not bent, moved and upper control arm is left "as is" (joint just slid off). It would seem to me that if there is no physical damage to the front end (bending, etc), that once the ball joints are re-install, that the alignment would be back to "normal". Is this basically a "true understanding" or do/would the alignment guys do some "magic" adjustments thereafter?? or would they just do a "machine check" and give me a printout saying everything is OK?
