Thanks a ton man.you can replace just the ball joints
Hey everybody. I'm just checking to make sure I understand this correctly. I have a stock 1998 Ranger 4x4. Can I go ahead and replace the upper and lower ball joints alone or do I have to get whole new aftermarket control arms to do so? I've ready (very quickly) in some places that you can't replace factory ones but after reading part of this post I think I can just replace the BJs.
Upper control arms and ball joints are one piece-balljoints can not be replaced on them.
I have beat the hell out of the knucle after getting the top joint removed. I have PB blastered it. I attempted to use a tie-rod separator and then a ball joint separator fork. Nothing is working here. The knuckle will not come away from the bolt joint at the bottom of my 2001 Sport Trac.
Any ideas? I just torched the bolt thinking it'd expand and then when it contracts, I'll try again. I'm out of ideas though. I'll have to reassemble everything in defeat, after having mangled the lower ball joint boot of course.
Might help to just put the torch on the boss around the ball joint shaft. Took me two hours of banging with a mini sledge and a pickle fork, and two minutes with the torch and a whack.
The sledge is the best way to do it, but it does take some experience/practice.
The trick is a big sledge hammer, and a 4lbs baby sledge will work. It really can't be done without the big mass of the sledge, any light hammer shouldn't do it.
If you haven't done it before, you will think it's a light weight job, just tap it hard enough that you don't hurt it.
That will not work, you absolutely must hit it as hard as you can while making sure to not miss the spindle. You take all the time as needed to get in the right position, laying doing or being able to swing both arms fully. You get where you need to be, to be able to swing the sledge very hard onto the spindle(ball joint bulge).
You have to hit that bulge with enough force to compress that steel. It takes the real sledge and its mass and a hard hit to be able to deflect that metal.
Once you get used to being able top hit the spindle in that way, you will be able to pop the BJ out in less than 10 seconds, or a minute or two at the most. No other tools or methods will ever work that quickly. Grab the sledge and smack the #### out of it.![]()
Just did these on my truck. I do not think the lower balljoints were stock and as a result the balljoint press was not much help. Instead, I heated the metal on the outside of the balljoint and basically beat them out with a few firm blows from a ball peen hammer. They came out quite easily.
Before I started, I put the new balljoints in the freezer overnight. With the control arm already heated, the frozen balljoints went right in using the floor jack method.
