Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
Hello,
I just replaced the left lower ball joint on my Sport and am having a problem connecting my Grease Gun to it.
I have a Linocoln grease gun that is supposed to be of good quality I am told, but when I attach it to the Zerk fitting on the Lower Ball joint grease just squirts out everywhere? I have use the gun on other things such as Tie Rod ends and such with no problems, though the Zerk fitting on the Ball joint seems much bigger.
I used a lower Ball Joint from Pep Boys called Pro Steer, seemed to be a good unit with a lifetime warranty, has to be better than the Moog units as of late.
I need this truck for daily driving and the Questions I have are: Is it ok to drive the truck with out grease in the Ball joint and Why wouldn't the grease gun work with the zerk on the ball joint?
Do I need to buy an adapter or something?
If this is a bone head question my apologies, it is my first ball joint replacement.
Thanks
Thanks
