Mine is not billet, but it had two brackets attached to each side; the plate was placed over the existing lower grille; behind the factory grille, you have to hold a little clip in place while running the screw through the bracket; the thing about the clip is it has to be held on there while the grille is on. I don't remember why the factory grille didn't come out, but it eventually worked (and was later reinstalled by a shop using better clips)
First you have to remove the lic plate and frame... sometimes they don't like to go back on so easily, so you might end up having to deal with that too.
