lower control arm | Ford Explorer Forums - Serious Explorations
lower control arm
randch
Courtland Ont.
96 XLT
We just bought a 96 explorer and whom ever owned the vehicle before welded the ball joints into the lower control arm and one ball joint needs to be replaced. I imagine that the easiest to do this would be to replace the hole lower but I'm not sure how hard it would be to change it. I know nothing about the torsion bar that is on this vehicle. Could someone give me some advise?
Apparently, this is a common problem- the sockets that hold the ball joint get too big and after a number of replacements no longer hold the ball joint.
To remove the LCA, you'll have to let the pressure off of the torsion bars, it can be a dangerous task, the energy stored in those bars is very powerful and can get away from you in a hurry. When you remove the torsion bars, index mark both ends so that they go back the same way.
Once the bars are removed, the LCA's are easy to remove, just two bolts, the shock, sway bar link and knuckle. Finding a quality LCA may be a trick in itself.
EDIT: Check in here for some "how to's" on the front suspension: http://www.explorerforum.com/forums/showthread.php?p=1784849
I guess it depends on how you define quality, but you can get new Ford LCA's from Fast Parts Network for around $90 a side. That includes the new lower ball joints and bushings.
http://www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=318&chapter=&Sectionids=19,2512&groupid=61005&subgroupid=0&componentid=0&make=10&model=Explorer&year=1996&graphicID=T028060&callout=7&catalogid=1&displayCatalogid=0
Well, that's not bad at all, I figured they'd be $300 ea or more. I'd be tempted to press out the OEM ball joint and put in a MOOG, it'd last longer that the OEM one.
I agree, MountaineerGreen. I was surprised when I looked up the price.
For that matter, I'd replace both control arms. And yes, I also second the recommendation to use Moog joints.
