lower control arm | Ford Explorer Forums - Serious Explorations
lower control arm
Borg
elk grove, il
2013 explorer xlt awd
I am replacing lower control arm and having issue with aligning up ball joint with knuckle. Does anybody have any suggestions? 2013 Ford Explorer XLT AWD
Can you elaborate? Would it help if you posted pictures?
Is the lower control arm the only thing that you have taken loose during its replacement?
When you broke the BJ free from the original control arm, did the spring cause the strut tower to shift sideways and you simply need to lever it back into position?
