Lower Gasket Kit 4.0 SOHC Engine. - SOLD
As I have said in a couple of other messages, I thought I was going to be able to replace the timing set on my '03 Explorer, low and behold a new engine is on the way. But I do have some stuff that I purchased for it that I would like to sell. I have a complete 97-09 4.0 SOHC Engine conversion gasket set. I don't know why they call it a "Conversion Set" But I do know that it is for trucks with the 8th digit of E, K, N it will also of course fit the Mercury, Mazda's and the Land Rovers with the same motors. It includes the following:
1 Oil Filter Mounting Bolt O-ring
1 Timing Cover Seal
1 Oil Pan Upper Gasket
1 Oil Pan Lower Gasket
1 Water Pump Gasket
1 Oil Pan Drain Plug
1 Oil Pump Inlet Tube Seal
1 Front Cover Gasket
2 Oil Pan Drain Plug Washers
1 Oil Level Indicator Seal
1 Oil Cooler O-Ring
1 Rear Main Bearing Seal
1 Oil Filter Adapter Gasket
It is a Sealing Tek brand kit, I purchased it last week from them for $54.99, I would like to get $40.00 for it and I will charge $5.00 for shipping, no matter where it is shipped to in the US, it is brand new in the original packaging, never been opened.
If interested, just drop me a note.
Dave
1 Timing Cover Seal
1 Water Pump Gasket
1 Oil Cooler O-Ring
Dave
