tombstone
- June 8, 2013
- Ca.
- 1994 Ford Explorer
After reading countless complaints with the Ford 4.0l lower intake manifold sealing solutions , I found out from FelPro techs that everyone suggests using RTV (Permatex Ultra-Black or other) around all the water jacket ports on both sides of a "carrier-style" gasket OEM F5TZ-9439-A & MS-90728; which will cause an improper sealing problem. Please note:
Equally important, the intake manifold and head surfaces must be clean (no grease, oil or coolant film) and dry. RTV, other sealants or adhesives should not be used around the coolant or intake ports on carrier-style gaskets. ... New intake manifold bolts are recommended.
