Lowered with RCD coilover stuff ? | Ford Explorer Forums - Serious Explorations
scruff
Atlanta, GA
2000 Limited chassis only
So has anyone lowered, or set up an Ex at stock height with an RCD Coilover kit?
I know they're advertised as a 5 inch lift kit (and they're supposedly ranger parts) , but surely with the bracketry all it would take is a different length set of shocks and springs ?
Anyone done this already ? I'd love to see some clos eup pictures of how the brackets look (even if on a lifted truck)
Thanks
the only parts the would be of any use would be the brackets to adapt to the coil over shocks. everything else will make the truck taller.
i have the RCD on my ranger.
i dont havea good pic of the bottom, maybe i can find one in a few
only problem you might run into is the thru bolts for the RCD are 9/16"
most universal c/o shocks ive messed with are 1/2"
findin a shock that will fit the application may be a task.
there are a few torsion bar rangers that have converted to c/o drops on RPS as well.
Thanks Gumby, thats exactly the sort of picture I was hoping for, just looking to see what they did at the upper mount.
MtGreen, thanks for the link, I actually read that post, but thought it was all lift oriented, it wasn't until I re-read it that I saw all the info on shock length and travel stuff.
I'd still love to figure out some way of putting airbags under these, but the only way I see doing it is either to cut off the upper mount, fab something else and then use something like a air-strut OR
Make a solid bar to replace the torsion bar and put the bag over it and the other end on the frame, sort of a backwards version of a rodders four link rear end.
The coil over are definately a consideration though. For now, I think I'll just leave everything stock, except maybe some shocks that'll allow travel right down to chopped bump stops.
Do you guys know the stock shocks spec ? length compressed and length extended ?
here is a nice shot of the bottom mount(not my pic)
Looking at that pictures it's no surprise that the torsion bars groan a lot is it ?
The keyway where the TB slips in is just bounds to junk up dry out and generally be crap. Great picture there.
I had a look at Edelbrocks site hoping for some more info, but theres nothig there. I'll have to research it later.
Thanks!
