moose1
- April 26, 2006
- coupville, wa
- 99 xlt
I was at autozone and peared at the universal shackels they have one a hole at the top of the shackel and then at the bottom there are the three hole to lift it using them. Here is my idea, if you cut the shackel about half way and used the three bottom hole right you could bolt the top hole in the factory hanger hole and bolt the leafs up to the last hole that three hole set up is almost 2 inches shorter than the stock shackels would that lower the ex.???
