Lowering the Explorer
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
To my knowledge, he used the same H&R spring kit that others have used with results much lower than the picture he posted. Let's not get back into the AWD / 4WD controversy that has been discussed too much already.:)
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
kevin1gonzalez
Miami, FL.
2014 Explorer XLT
i hear u- im just worried now because i just ordered my lowering HR kit for my 2014 XLT and hoping that i dont have the same results on my EX.
-Kevin
slikirish
Dub Vee
2011 Explorer XLT
AWD and 4WD to my knowledge are not the samething- which in this case may be the reason why his suspension sits so high- i believe you have to remove something other than the springs in order to reach the lowered hieght you desire.
What could this other something else be? The front looks great, the rear is just still up in the air some. I actually got to look at mine next to a stock XLT tonight. Mine is certainly lower all the way around, just more so in the front.
Does anyone know if the rear springs have to be turned a certain way? I know on the New Edge Mustangs, the end of the coil on the bottom has to point toward the drivers side or else it doesn't sit right. Anyone know of something similar on these?
JETZ
2012 Explorer Limited
That's what all serial killers say!
The one and ONLY reason I bought this vehicle was to have the seating. I have three boys that can't sit three across a backseat b/c all they do is fight, argue and make me want to commit a triple homicide. I would've much rather kept my G8 GT but this was the right move to make for the family. My Ex will never see dirt road, ruts or anything.
So in the meantime, I would like to see it be low, slow and long. I have a set of 22's to put on it. However, being chrome and dealing with WV winters, I'm not going to put the tires on them until next spring.
Edit: Obviously joking about the triple homicide...
slikirish
Dub Vee
2011 Explorer XLT
[/I][/B]
It takes more than 3 to be serial right? Like if I take them all out at once that's just a triple. Now if I take each one out on their birthday's, then I've shown a pattern and it becomes serial. I may be overthinking this just a touch.
JETZ
Just a touch. :D
285ferrari
Maryland
2014 Sport - Darth Vader
HAHAHA!!! I have four boys, I KNOW THE FEELING!!!!
peterk9
Staff member
Moderator
Callsign
VE3
You mean standard on sport? Not all limited explorers are AWD.
Okay I guess I should have explained that. All Limiteds in Canada are AWD.
slikirish
Dub Vee
2011 Explorer XLT
Looking at all the pics of what I was trying to get mine to look like, none of them have the "4WD" moniker on the back. Wonder if that's what is causing me the problem.
peterk9
Staff member
Moderator
Callsign
VE3
There are pics of the lowered Sport and all Sports are AWD. The one in the pics without the 4WD on the back have likely been 'debadged' as some members have done.
slikirish
Dub Vee
2011 Explorer XLT
Well there goes that theory then. It does seem to be settling some but not quite to what I've been seeing in pictures. Thinking the isolator's are going to come out. Then probably wait until the spring when I put the new wheels/tires on and see where it is at that point and go from there. I'm not looking for the "tucked" look but certainly more a low, slow and wide look.
bl0atedg0atz
Greater Lansing Area
2015 Ford X Limited
Did the springs ever settle using the Explorer kit 51630?
kevin1gonzalez
Miami, FL.
2014 Explorer XLT
I just lowered my 2014 XLT utlizing the 51630 HR Ex Springs and it has settled about two weeks now- its a moderate drop- was hoping that the rear would have been a half inch lower but I like it. I know for a fact that the FLEX springs give you a more aggressive drop. Also the SPORT model has a diff. suspension which allows for a lower profile utilizing the same EX sprngs. I dont understand but it appears to be the case. I will be posting pics soon to show comparison and also measurements.
bl0atedg0atz
2015 Ford X Limited
That would be great if would do that. The next question is if I used the Flex spring kit would I still be able to tow? I know there are a couple of posts for that kit on the sport edition and being to low for towing heavy. I assume the Flex kit sits higher on a non sport edition maybe?
kevin1gonzalez
Miami, FL.
2014 Explorer XLT
you can possibly tow with the FLEX kit on a non-sport- My measurements are as follows:
Before:
Front-31 3/4 (31.75)
Rear- 33 1/8
After:
Front-31
Rear- 32
So basically 3 quarters of an inch drop in the front and an 1.25 inchs in the rear. I havent been able to take pics but will be posted by the end of the week.
slikirish
Dub Vee
2011 Explorer XLT
They have settled some. I, like other people, wish the rear would sit another 1/2 inch lower, but it is definitely lower than it was in my previous pictures. The front is just about perfect, the rear just is still flapping in the wind a bit. Hoping putting the 22's on and the offset pushing wheels out toward the fender will help. However, I won't know about that until spring time.
kevin1gonzalez
Miami, FL.
2014 Explorer XLT
Have you aligned it yet? if so did it help? i havent aligned mine yet
