Lumbar support problem
Zippy5150
Woodstock, GA
04' Explorer ST XLT
I have an 04 ST. The lumbar support pump will run if I push the switch, but the bladder isn't filling up. What is the most likely cause and where should I look first? Do I need to remove the seat?
Squirrelmaster
St. Paul, MN
'04 Explorer Eddie Bauer
I have the same issue, though since I never use lumbar adjuster I had actually forgotten about it until I read this post. Now that the weather here in Minnesota is becoming a bit more hospitable, I may have to go out and investigate the problem if I ever get a chance. Sorry I don't have anything else to add that might help Zippy.
Tom
ncranchero
Co-moderator
Staff member
Moderator
Denver,NC
'94 F150 4x4 SWB 4.9L
There's a little hose that goes from the lumbar compressor, probably mounted on the seat frame under the seat bottom, to the lumbar bags. Either it has become disconnected at the pump or bags OR the bag/bags have a leak.
1 Power lumbar motor electrical connector.
2 Power lumbar bladder hose.
3 Power lumbar motor.
Zippy5150
Woodstock, GA
04' Explorer ST XLT
Well I pulled the seat out and checked the air hose. It looked good, so I guess the problem is with the bladder. Oh well no Lumbar support.
jad2411
El Paso, TX
2007 Brown eb
You could try one of those bycicle repair kits, maybe it will seal the leak? It's already messed up, I don't think it'll matter if it doesn't work :p:
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
I would like to try the patch on mine, but am not really sure how to access the bladder...does anyone have any tips or advice?
Thanks in advance,
Mike
