I just picked this up for me Mum and Dad. The way the world's weather is going at the moment I reckon its crazy to rely on the usual comms systems. Now when the flood, earthquake, tidal wave, bush fire, cyclone, hurricane, tornado and next ice age happen I can still invite them over for a cup of tea.
GME TX680
3 WATT UHF HANDHELD RADIO
1 YEAR WARRANTY
The GME Electrophone TX680 is the latest in GME's line of compact UHF 40 Channel Handheld Transceivers. Not only is the TX680 packed with features, its circuit design incorporates a super sensitive receiver with front end filtering and a powerful 3 Watt transmitter. The TX680 is not just another one of the many compact units currently on the market today. GME have spent a considerable amount of time engineering the TX680 to fulfill the needs of our users and meet the performance expectations that GME products are renown for.
What sets the TX680 apart from the rest of the pack is its superior performance. The TX680 has a full three Watt RF output which is six times the power of many units on the market today. For close range communications the transmitter can be switched to one Watt to increase the available talk time. The receive sensitivity and front end filtering of the TX680 meets GME's high standards and you will find the unit is unbeatable in all areas. The TX680 comes complete with a flexible antenna, carry case, desktop charger and a 1000 mAh Li-ion Rechargeable Battery Pack with enough power for a full days work.
Scan
Will scan through all 40 channels
Dual Watch
Allows you to set the Radio to monitor any two selected channels
CTCSS
This feature allows you to select one of the 38 codes per channel
VOX
When speaking, the radio automatically detects your voice and transmits wihtout the need to press the PTT (Push To Talk) button
Roger Beep
When activated, the radio will send a short 'beep' when the PTT button is released
Duplex Capable
Used to access one of the many UHF repeaters around the country
Calling Tone
One of five ringing tones can be selected and transmitted on any channel to alert other users that you are trying to make contact
Auto Power Save
After a period of not transmitting or receiving, the radio automatically switches to power save mode
Key Pad Lock
When activated, the front buttons are disabled preventing accidental key press
Accessory Connection
The radio provides a connection socket for the optional ear and speaker microphone
Monitor Switch
Pushing the monitor switch will open the radio squelch
LCD Display
The battery level and signal indicators are displayed along with the selected functions
IP54 Ingress Protected
Protection against entry of dust in sufficient quantity to interfere with satisfactory operation of equipment Protection against splashing and spraying water from all practicable directions
Includes
TX680 Radio
Removable Flexible Antenna
1000 mAh Li-Ion Battery Pack
Semi-Quick Charger
AC Adapter
Carry Case
