G
geoph1986
Hello All (again),
First and foremost, thanks to all that have helped me with my problems in the past. I've said it before and I'll say it again, what a great site this is.
I have a 1994, Explorer XLT 4X4, 4dr with the stock 4.0L.
Anyway, my high mileage A4LD has sprung a leak at the front seal. I've read that these transmissions are s**t at the best of times, so I would like to drop in a manual transmission. Also, since I have to pull the T-Case, I would like to get rid of the electronic shift and put in a manual shift.
I don't do any hardcore wheeling (yet), my X sees a bit of off road use for fishing, hunting, and camping. I also don't do much towing, and the towing I do involves a 16ft aluminum boat and trailer and sometimes helping a buddy get home to save the cost of a tow truck.
So I've read that this is a bolt in type swap, and I believe I know what parts are needed from a donor rig.
I used my Hollander Interchange, and it says that I can use the following manual transmissions:
EXPLORER 91-97 M.T.; 4x4
MAZDA B-4000 94-97 M.T.; 4x4
MAZDA NAVAJO 91-94 M.T.; 4x4
RANGER 90-97 M.T.; 4x4, 6-245 (4.0L)
Is any one year of transmission better than the other? And why is it better or not. If I use a certain year, am I looking at more of a headache than using a different year? Is there anything I should think about that I haven't asked?
Hollander Interchange says that I currently have an electronic shift Warner 1354 T-Case, and it says I can use the following manual T-Cases:
BRONCO II 90 4x4, Warner 1354, manual shift
EXPLORER 91-95 manual shift
MAZDA B-2300 94 (Warner 1354), manual shift
MAZDA B-3000 94 (Warner 1354), manual shift
MAZDA B-4000 94 (Warner 1354), manual shift
RANGER 90-93 Warner 1354, manual shift
RANGER 94 (Warner 1354), manual shift
Again, as i understand it, this too is a bolt in swap. I have all same questions that I have regarding the transmission (just replace the word transmission with T-Case). Is there an easy way to tell by looking at the T-Case that it is a 1354 and not a 1350? I will be getting these parts from the junkyard and would like to avoid getting the wrong one.
I know that with the transmission I will have to do some wiring mods, so I can start and drive my X with the stock ECU. What type of wiring mods (if any) need to be done where the T-Case is concerned? Or can I just abandon the wiring for it? Have I forgotten anything that I should have asked?
I know that this has been a long winded post, but I like to be thorough, so I can have a lot of the variables out of the equation when getting help from others.
Thanks in advance to all.
EDIT: I have currently abandoned my plans for the V8 swap due to time and money, or should I say the lack of time and money...mostly money. I want to do the swap right, not just a hack job.
