xlt4wd90
- February 22, 2010
- Southern California
- 1990 XLT
I hope Josh P sees this as he suggested that I start my own thread.
I'm about to install a M5OD-R1 into my Aerostar to replace the original A4LD, which died recently. I got the master cylinder for the Aerostar and not sure what kind of fitting it needs. Josh (and someone else) mentioned that they were able to build their own hoses using AN fittings. Can you give some details on that?
The slave cylinder side has a quick-connect fitting. Did you replace that as well?
thanks in advance
thanks in advance
