M5OD-R1 HD swap 1994 ford explorer | Ford Explorer - Ford Ranger Forums - Serious Explorations
Mulletmaster
Stanwood Washington
1994 Explorer XLT
I recently swapped a m5od-r1 hd transmission into my 1994 ford explorer that was originally an automatic. I got a new clutch, flywheel slave and master cylinders. After I went to start it up it sounded like the starter was sticking, I then pulled my (auto) starter and installed a new manual starter. I just got everything back together and it still sounds like it's sticking, at first I thought it was from the ignition still applying power, so I jumped the starter soleniod, still stuck. I tried shimming and still stuck, has anyone has this problem or know a solution?
kumar_svt
East Los Angeles, CA
1991 Ford Explorer 5SPD R
Is there a difference between the manual and auto transmissions? I have a 1991 explorer manual. But i want to go past the 85 mph limit. In other words is there a transmission that would fit that will give me that range of speed.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
How old is the battery? Maybe it is getting weak. Can you turn the motor over with a wrench?
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
From personal experience, the automatic transmission will not hold up to excessive speed for long periods of time. Also if you post a new thread, someone is more likely to see it and help you out with your question.
Mulletmaster
Stanwood Washington
1994 Explorer XLT
The battery is fine, it turns over fine, it starts and it doesn't disengage when the engine is started
Mulletmaster
Stanwood Washington
1994 Explorer XLT
I swapped my transmission because it started to slip but with the auto I could go 100mph
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@Mulletmaster
Check diameters of starter pinion gears. It may be that there is not enough clearance to allow starter drive to disengage. Which would mean, if that's the case, the starters for manual trans. are listed as different part number. imp
Mulletmaster
Stanwood Washington
1994 Explorer XLT
@Mulletmaster
Earlier today I got my hands on a starter for the correct year, make and model and it still hangs up, I think that I have it pinned as the starter relay, will test tomorrow
