Mach Power Antenna | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
Mach Power Antenna
merlinct7
Tolland, CT
2000 Mountaineer
My newly-acquired '00 Mountaineer has the Mach audio, without a power antenna. IDK whether the existing antenna is original, but I want to add the power antenna. Did all Mach systems come with connectors for the power antenna?
If so, I think I should be able to mount an Explorer power antenna and simply plug it in. If not, how would I connect one?
Appreciate any help!
the headunit has a "remote on" wire... without a power antenna, that wire is used to turn on an amp, but is also used to turn on the antenna motor to move the antenna up.
I just removed the antenna from my rolled 99 parts donor Explorer. There are three wires going to it, plus the antenna wire. It's all one piece, with a bracket, and the top cover pieces, and three torx screws. With the correct radio, it should bolt into any 95+ Explorer, etc. Good luck,
DonW
