koda2000
- September 2, 2011
- x
i just bought a used Mach radio from another forum member. it's out of a 2001 Explorer and is to replace the broken radio in one of my 2000 Mountaineer's. although the seller's vehicle had the CD changer, steering wheel mounted controls and amp/sub woofer, the part number for the radio was different from the original radio out of my Mountaineer (no big surprise there, as they're from different years). i was concerned there might be a wiring, or some other incompatibility, between the years, so i pulled the radio out of my 2001 EB and tried it in the 2000 Mountaineer and it worked fine. i should note that the part number on my '01 EB radio was also different from the seller's radio, but i figured it should work.
i received the radio yesterday and installed in in the Mounty. it seems to work perfectly in every respect, but there are several differences. firstly, the display layout is a bit different (for example, the clock is in the center of the display, instead of on the right-hand side) and there is no RDS button. however, neither of these things bothers me.
here's what has me puzzled, all three of my Mach radio equipped vehicles have 3 plugs that go to the back of the radio. this radio only has pins for 2 plugs. the smallest square plug has a hole to plug into, but there are no pins in the hole. as everything seems to work (CD changer, steering wheel mounted controls, rear seat controls, amp/sub woofer) what the heck is this little square plug connected to? i've looked at the wiring diagrams, but if the answer is there, i don't see it. :scratch:
