danlong
- October 16, 2003
- Gainesville, FL
- 2001 Sport Trac 2wd - V8
Trying to track down my stumble/lack of power, I pulled 3 codes.
137 - 02 sensor, voltage signal not switching during engine run self-test
159 - MAF sensor, signal voltage is higher or lower than expected
565 - CANP, canister purge solenoid circuit failure
565 I know is due to the CANP not being present, and I haven't tested the 02's yet. I did test the MAF though, according to the book on Ford Electronic Fuel Injection, and everything checks out fine. Voltages are correct, no short circuits, everything also seems kosher at the ECM. I've only driven the truck about 150 miles since the MAF and K&N was put on, but the original MAF and intake was causing the same problem. I'm thinking possibly a bad ECM? Or could a bad 02 cause another code to be triggered?
