Maniak - September 2013 TOTM | Ford Explorer - Ford Ranger Forums - Serious Explorations
Here is our September 2013 TOTM winner.
Winning Picture:
Specs as of 10/13
1992 Ford Explorer XLT 4x4
700r4 transmission using Advanced Adapters kit
fl1a filter & mount re-tasked for external transmission filter
2 transmission coolers mounted in front of the a/c condenser
10" fan from a geo prism mounted on 1 cooler with Relays & a capacitor to control transmission cooler fan.
Rancho RS9000 shocks (rear)
Front/Rear sway bars removed
BFG AT 32x11.50 on 15X8 rims
Modified stock axle pivot bracket (pass side) to increase strength
Extended steel braided brake lines - (had to modify stock fitting on front driver side)
4.10 Gears
Detroit Locker in Rear
Trac lock from Jeep Dana 35 in front TTB D-35
Warn Manual hubs
Custom front bumper (designed for maximum approach angle)
New roof rack cross bars using stock sliders to hold Coleman basket
Custom Tube rear bumper (designed for maximum departure angle)
Extended Front/Rear Diff breather lines
Rear shock mounts moved to Swaybar mounts.
Extended Stock Radius arms with Ballistic Joints and custom mounts.
F-250 shock mounts with 32" long Rs9000 shocks.
SOA using a modified OME-36 spring pack and stock shackles (ruffstuff spring perch)
C-Clip eliminated using Echo spring and split colar
LED rock lights
Pair of 6" LED light bars from TWF on front bumper
Pair of 5" halogen lights on front bumper
3/16 steel welded to bottom of front TTB after fixing the Dent/crack in the bottom of the Beam.
Many Cracks in Beam welded up..
Opened front axle beam window
Moved Cat Converter back almost 12" to free up room next to trans.
Audio upgrades
Kenwood CD player (don't remember model number)
Sony XPLOD - 754 (350watt.. 75x4) for mains
American Pro 400 watt rms x 1 for sub
Clarion Pro 5x7 plates (front doors)
Rockford Fosgate 5x7 - 2 way (rear door)
MTX Thunderform Sub enclosure
Custom storage compartment in rear for spare parts and even more tools
Links:
SOA thread: http://www.explorerforum.com/forums/showthread.php?t=391276
Rear Bumper thread: http://www.explorerforum.com/forums/showthread.php?t=368184
Extended RA w/ ballistic joint thread: http://www.explorerforum.com/forums/showthread.php?t=246044
Skidplate strengthening: http://www.explorerforum.com/forums/showthread.php?t=201883
LED rock light upgrade: http://www.explorerforum.com/forums/showthread.php?t=393521
Pictures:
Congrats Maniak!!!
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...I just saw this...Congrats...:biggthump
