bronchole
Driveway flexing!
- May 13, 2009
- Los Angeles, CA
- 1997 Monsterneer
- Callsign
- KI6MCO
I was driving down the freeway last night towing a 3000lb or so trailer. Cruise control set to ~60MPH, running a slight downhill section of the 5 for a couple miles. All of the sudden the rpm's shot up to 5K. That caused the CC to turn off. I move over to the shoulder and stop. Play around a bit, its acting like the T-case is in neutral because if I try to put the trans in park I can hear the ZZZzzZzzZZZZ of the parking pawl not getting it. Put the trans back in neutral and try to shift the t-case. ****er moves thru the ranges just fine and the 4X4 shift light seems to work as I would expect. Hmmmm, put the trans back in drive and I got gear, but too much gear, its in low range even though the T-case shifter is in the 2WD position. I fart around a bit shifting the transfer case back an fourth thru the ranges and it seems to stay in low rang the whole time. I'm only about 15 miles from home at this point so I elect to get off the freeway and drive it home in low range.
This morning I go out and verify my situation. ITs stuck in low range and no ammount of shifting the manual shifter will get it out. 4X4 light is on in the 4H and 4L position, out in the 2WD and Neutral position. All positions have the t-case in 4L.
I go in to the garage and do a bit of looking around in my previous 4406 which has a nice break away view (case is broken in half) to check out what is going on in there and the only thing I can think of is that the plastic shifting fork is junk and not shifting the T-case thru its ranges.
I did a bit of searching and found a couple other simmilar instances, but most seem to be electric shift T-cases and the owners not knowing how to shift them.
I'm thinking its time to go look for another T-case to swap in. I was supposed to go on a Death valley trip next weekend, but I think this is going to kill that trip.
I guess I need to also find the list of tools I need to extract one and what vehicle will have the manual shift 4406. I don't need to worry about the tail housing type, I can re-use one of mine if I don't happen to find a 97 with the speed sensor in it.
