Cstoliker
- July 19, 2008
- 2000 Explorer XLT
95 Explorer XLT I have flat out given up trying to find a replacement GEM module for my truck. I am just going to use 4x4 manually. I already have done the Brown wire mod so I can engage the T-case with the flick of a switch. The problem is I have to move the selector from 2wd to 4wd to engage the C.A.D. and this bring my malfunctioning GEM into service witch can and does engage the T-case sporadically. Is there a way to manually rig a switch to engage Center Axle Disconnect? Or even turn it into a live front axle?
Seams the C.A.D.s are more trouble then there worth. They work perfectly except when you need them.
