ron94sport
- January 23, 2001
Based on the search of this topic that I performed, the clutch is a ***** to bleed. I suspected that I had air in the line and attempted to bleed. I hit the depressed and released the clutch with the bleed open and now the pedal moves freely...air into the master cylinder (whoops). Anyway, I read about several methods of bleeding the system on this site including the following:
1. Follow Haynes manual prodedure of bleeding by gravity through the bleed fitting.
2. Use a crow bar to actuate the slave cylinder, then follow the Hayes procedure.
3. Disconnect the master-slave cylinder line and bleed as described in the maintenance tips section.
4. Bench bleed the master cylinder, reattach and follow Haynes procedure.
Can anyone provide insight as to the easiest and most effective way to bleed these systems?
Thanks much in advance.
Ron
Ron
